GT-R Register - Official Nissan Skyline and GTR Owners Club forum - View Single Post - Java help please
Old 31st October 2008, 01:00 PM   #3 (permalink)
moz
moz has no status.
Cars owned: R32 GT-R
This works, just the formatting of the output needs sorting from the DisplayCalendar() method, I'm not to great with formatting. I'm sure you'll manage
Code:
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
public class Calendar4 implements ActionListener
	private JFrame outputFrame;
	private Container container;
	private JLabel yearLabel,  monthLabel;
	private JTextField inputYear;
	private JButton myButton,  calcButton;
	private ButtonGroup myButtonGroup;
	private JTextArea myTextArea;
	private JComboBox inputMonth;
	String days[] =
		"Su ", " Mo ", " Tu ", " We ", " Th ", " Fr ", " Sa "
	String months[] =
		"January", "February", "March", "April",
		"May", "June", "July", "August", "September",
		"October", "November", "December"
	int DaysInMonth[] =
		31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31
	protected String[][] calendar =
	public static void main(String[] args)
		new Calendar4();
	public Calendar4()
		outputFrame = new JFrame();
		outputFrame.setSize(500, 400);
		outputFrame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		container = outputFrame.getContentPane();
		container.setLayout(new FlowLayout());
		container.setBackground(Color.RED);
		yearLabel = new JLabel("Enter Year (After 1900)");
		container.add(yearLabel);
		inputYear = new JTextField("", 10);
		container.add(inputYear);
		inputYear.addActionListener(this);
		monthLabel = new JLabel("Select Month");
		container.add(monthLabel);
		inputMonth = new JComboBox(months);
		container.add(inputMonth);
		inputMonth.setSelectedIndex(0);
		inputMonth.addActionListener(this);
		calcButton = new JButton("Press To Display Calendar");
		container.add(calcButton);
		calcButton.addActionListener(this);
		myTextArea = new JTextArea(10, 40);
		container.add(new JScrollPane(myTextArea));
		inputYear.setText("2008");
		outputFrame.setVisible(true);
	public void actionPerformed(ActionEvent event)
		if (event.getSource() == calcButton)
			myTextArea.setText("");
			if (!YearInputIsValid()) return;
			int userYear = Integer.parseInt(inputYear.getText(), 10);
			myTextArea.append(isLeapYear(userYear) ? "Is a leap year.\n" : "Is not a leap year.\n");
			fillCalendar(userYear, inputMonth.getSelectedIndex());
			DisplayCalendar();
	private void DisplayCalendar()
		for (int i = 0; i < calendar.length; i++)
			for (int j = 0; j < calendar[i].length; j++)
				myTextArea.append(calendar[i][j] + " ");
			myTextArea.append("\n");
	private boolean YearInputIsValid()
		if (inputYear.getText().equals(""))
			myTextArea.append("Please enter a valid year value.\n");
			return false;
		try
		catch (Exception e)
			myTextArea.append("The entered values must consist only of numbers,\n");
			return false;
		if (Integer.parseInt(inputYear.getText(), 10) < 1899)
			myTextArea.append("Year must be 1900 or after\n");
			return false;
		return true;
	private void InitialiseCalendar()
				calendar[i][j] = " ";
	private void fillCalendar(int userYear, int userMonth)
		InitialiseCalendar();
		int xNum = (CalcFirstOfMonth(userYear, userMonth));
		int yNum = 0;
		int numDays = DaysInMonth[userMonth] + ((isLeapYear(userYear) && (userMonth == 1)) ? 1 : 0);
		int day = 1;
		do
			calendar[yNum][xNum] = String.valueOf(day);
			xNum++;
			if (xNum > 6)
				xNum = 0;
				yNum += 1;
			day++;
		} while (day <= numDays);
	private int CalcFirstOfMonth(int userYear, int userMonth)
		int startDay;
		if ((userMonth < 0) || (userMonth > 11))
			return (-1);
		startDay = CalcJanuaryFirst(userYear);
		for (int i = 0; i < userMonth; i++)
			startDay += DaysInMonth[i];
		if ((userMonth > 1) && isLeapYear(userYear))
			startDay++;
		return (startDay % 7);
	private int CalcJanuaryFirst(int userYear)
		return ((5 + (userYear - 1582) + CalcLeapYears(userYear)) % 7);
	private int CalcLeapYears(int userYear)
		int leapYears;
		int hundreds;
		int fourHundreds;
		leapYears = (userYear - 1581) / 4;
		hundreds = (userYear - 1501) / 100;
		leapYears -= hundreds;
		fourHundreds = (userYear - 1201) / 400;
		leapYears += fourHundreds;
		return (leapYears);
	private boolean isLeapYear(int userYear)
		if ((userYear % 4 == 0) && (userYear % 100 != 0) || (userYear % 400 == 0))
			return true;
		return false;
Shamelessly butchered a little bit from here:
CalendarTable
Hope you don't mind the changes to some of your code, I get carried away sometimes Maybe you can just take what you need to fix the original code.
moz is offline   Reply With Quote
