Old 26th June 2008, 06:06 PM   #1 (permalink)
Seeking better cooling distribution in block
Hello,
I been trying to figure out a way to equalize the cooling done within the rb26. I know that the engine gets progressively hotter starting at cylinder one to cylinder six being hottest. This is what I believe the reason why #6 runs leaner.
I heard of a GT mod, which eliminates the ITBs, but it is out of question, I am going to keep the ITBs.
I also heard there has been modifications to widen the passage ways for coolant flow better at the rear of the head, anyone done or seen this before?
And lastly, I know the n1 block has been designed to have better coolant flow, does anyone know what the difference in the flow of the n1 compared to stock?
Thanks for your time.
makenski is offline   Reply With Quote
Old 26th June 2008, 06:17 PM   #2 (permalink)
Spearmint's Avatar
I can't really help with your questions other than I believe when tuning a little more fuel is thrown in the last couple of cylinders to compensate for the poor coolant circulation to the rear of the block.
Spearmint is offline   Reply With Quote
Old 28th June 2008, 05:19 PM   #3 (permalink)
paul cawson's Avatar
The rear cylinder head welsh plug is removed and the water ways cleaned and polished
Old 28th June 2008, 08:01 PM   #4 (permalink)
It's your car, if that is your car on your sig, that I heard this widening was done. I have all my freeze plugs out, so upon visual glance, I see two passage ways to near front of the hole, and two on the immediate sides of the hole.
In other words, can you be more descriptive. Plus, how did this effect your cooling?
Thanks.
Old 28th June 2008, 10:55 PM   #5 (permalink)
No not mine, its a well known dRIFT R32 GTST,with RB26 fitted and as you say the head water way modifications.
Old 29th June 2008, 03:03 AM   #6 (permalink)
kismetcapitan's Avatar
Good info - I assume the welsh plug is reinstalled after the polishing!
Old 29th June 2008, 05:42 AM   #7 (permalink)
Hmm.. I have a problem with polishing the coolant, due to the dipples are meant cause turbulence, which allows more coolant to spread over the area, by adding a smooth area the hot coolant will just want to flow over the surface continously, instead of mixing with the above flow...basicly it loses it cooling potential.
It's too bad you can't tell more about that mod.
Old 29th June 2008, 09:44 AM   #8 (permalink)
beaumackenzie's Avatar
this is where i think the earlier rb20dets still had a advantage over the later rb's with the three seperate pipes coming out from under the intake manifold back to the radiator as it let the hot water flow away from the back of the block sooner than the rb25's and gtr's as the water still has to travel back along the intake side of the block before exiting back to the radiator...it was a good idea i dint know why they removed it from later designs.
Old 29th June 2008, 11:06 AM   #9 (permalink)
Wink
Yes its easy to make things worse with only half the picture, I know that on a smooth surface micro bubbles form which help heat transfer, the opposite to what seems logical. The plug is not put back after but a screw in type fitted. This may be bigger to gain better access I will have to try and find the pictures of the mod again
Info on cooling and micro bubbles
BOILING HEAT TRANSFER
Old 29th June 2008, 05:47 PM   #10 (permalink)
SamuraiSam's Avatar
To prevent air bubbles (that prevent direct block-to-water contact, hindering heat transfer) use a cooling system surfectant such as Redline Water Wetter. Using a 33/66 mix of distilled water to ethylene glycol coolant helps too.
Old 29th June 2008, 08:32 PM   #11 (permalink)
I been summing up that trapped air is causing the rb cooling trouble, and possible caviation.
Which makes sense since water boils, so by raising the pressure of the system raises the boiling temp of water. But trap air within the system creates hot spots.
Old 29th June 2008, 09:02 PM   #12 (permalink)
gibson's Avatar
why change the block and head water ways ??? why not increase the radiator or go charge cooling ...and air removal tank.
Number 6 is lean due to air fuel mix not really water temp.
I do agree with the trapped air idea hot spots are present due to the long 6 cylinder lay out of the RB ..water and oiling do cause a few small probs.
just my 2p
gibson is offline   Reply With Quote
Old 29th June 2008, 09:40 PM   #13 (permalink)
GT-R Glenn's Avatar
Dual entry fuel rails .
I have pcx somewhere of a mod for waterways ..
Ill try and find it
Old 30th June 2008, 01:31 AM   #14 (permalink)
whoa, so if you have a dual entry fuel rail then the extra-fuel-on 5-and-6 isn't necessary anymore?
I would still keep extra fuel (just a bit) on those as they are still subject to being hot (last to get coolant as mentioned) plus #6 gets all the leftover air not used by the other cylinders (causing lean running). Until I get a Nismo intake plenum, its cheaper to just add a bit of fuel via the injector trims
Old 1st July 2008, 01:50 AM   #15 (permalink)
GT-R Glenn's Avatar
You dont have to reinvent the wheel, all this stuff has already been done.
I found this on one of my old cd's
Not written by me, just collected.
This is the GT cooling setup you see on some of the race
cars such as JUN and the Exvitermini stuff.
Using a mill you plunge down to the water passage
in the manifold between ports 1-2, 3-4 and 5-6.
I then welded a -8 male an fitting to the manifold.
This will run to a reservoir that will also be a merge
for the water returns for the turbo's.
From there it will run back to the radiator.
Basically, all the water leaves the head and runs to
the front of the intake via the log on the bottom.
To help expidite coolant flow from the head we supplement
by adding additional outage points from the manifold.
It would have probably looked a bit more clean on the
bottom of the manifold, but might as well show it off.
