R33 GTR project- From engine change to full refurb!
I had always wanted an R33 GTR had 2 s14a's one which i put an rb25det in and i have had a gtst. The time came where i thought i could afford a GTR so i began looking. I found a few around my budget but all needed work on them. Then i cam accross mine 96 on an N in silver 56k on the clock but blown engine. I went to see it and it looked good surface rust underneath as it had been stood for some time in a barn. It also came with a low milage lump on a pallet form japan. So i parted with my cash and paid 7k for the lot, whole car with blown engine and a complete low milage lump.
I was looking forward to start work on my new GTR, a nice simple engine change...BUT! On removal of the engine i found small patces of rust on both strut tops, after a quick look on here i found this was fairly common so not too worried! But i also found patches on the front and rear faces of the struts and inside the wheel arches, where your feet would be on the inside. If that makes any sense? so I decided to go crazy and do the whole lot, i stripped the engine bay and front end completly, inc subframe etc. FRONT END STRIPPED ![]() I then began work on the rust first the strut tops, i cut away the part beggining with 'f' cant remeber the name at the min! STRUT TOP REMOVED ![]() I then got rid of all the rust to see what i was left with ![]() I also found a hole in the C section that the top arm mounts to if you to the left of the pic above you can see where i have welded a new piece in, it was about 6inches long by 3 inches wide (welding skills arnt great i know but i am learning!) Next was to weld a new piece into the top of the srut, i had a donar vehicle but on removal they wernet great so i decided to use new metal and shape it to look as factory as possible. i did this to both sides as well as weld new metal where any rust was. i then stripped all loose paint etc off the front end ![]() ![]() i also seam welded the strut tops. I then filled where i had welded then sent it to the sprayers on my raf base and had the engine bay painted, on its return i wax oiled the inener wings inside the chassis legs and the underneath of the front of the car. ![]() ![]() ![]() ![]() ![]() ![]() ![]() While doing this all of the subframe, suspension arms, hubs, steering rack etc was away being shot blasted and powder coated! I ordered all new ball joints and track rod ends I wil add pics of these soon i also started on the engine, i was goin to just drop the new engine in but i got hp hungary so orderd N1 oil pump N1 water pump Cambelt kit Crank shaft oil seal 2xGarrett gt2860-5 splitfire coil packs tomei 1.2mm steel headgasket kit I also sent all my cam covers, cambelt cover inlet plenum, coil pack covers and twin turbo pipes to be shot blasted and powder coated. I stripped the engine and sent the block and head to be cleaned and re-faced. i also took the crank and pistons and had them cleaned and all the bearings checked to see if they need replacing. I was told that the bearings were all good and that the engine showed signs of being very low milage which i was pleased about. This is the stage i am at know i will update as i progress! ![]() |
HardcoRe GTROC Member
AWESOME WORK mate!!! Bringing 'em back from the dead is where its at not breaking 'em!! Top effort, will be watching this one progress, good luck!!
Ben
Ben スミグズ My GTR Development Thread - Team QM1 GTROC North West Regional Rep Life is not a journey to the grave with the goal of arriving safely in a prettily preserved body, but rather to skid in sideways in a shower of gravel and party shards - thoroughly used, utterly exhausted and loudly proclaiming "f**k me, that was brilliant!!" |
I am at raf leeming prob a dist but if you were willing to travel i would happily help you got 99% of tools inc 2 poster and 4 poster, welder press etc etc so if anyone needs a hand or use of these facilities drop me a pm and i will sort it out!
#8 (permalink) | |
will be when i get to drive it never bought a car and never driven it! would love to go forged etc but just cant afford it with payin for my weddin on a very very small wage! might hold off puttin it together and go forged, you have put a little devils wisper in my ear! |
Cool!
I remember when mine was just a bare chassis like that!
ok Decided to leave internals just dont have the fundings and when i do i will just take it back out
So Started building the engine back up last nite bottom end rebuilt head on with 1.2 tomei gasket, cams back in rocker covers back on block and head had a fresh coat of paint, n1 oil pump fitted, n1 water pump fitted, i will post pics 2mow. Any comments welcome |
#12 (permalink) |
you want a sump baffle. I went Tomei, seemed simple enough. You need a Power FC and Z32 air flow meters. Keep the redline down to around 7500rpm and with a good, safe, solid map, you should get some good mileage out of that stock bottom end.
btw, what were your bearing clearances when you rebuilt the bottom end? |
#13 (permalink) |
Cant remember what they were have them written down somewhere! will see if i can dig them out, taking the car to rising sun for there managment, Going for nismo afms next year with some bigger injectors. Was going for d-jetro but got advised not to bother!
What sort of power should i see? |
#14 (permalink) |
Nice, good effort. Seeing a bit of dejavu here. Post up more pictures as the pics will speak a thousand words!
. . . . . . . . . . . AUDI QUATT TURBS 20V, LANCIA INTERGRALE EVO 2, GOLF TDI ANNIVERSARY CHIPPED 250 BHP, KAWASAKI ZX7R |
#15 (permalink) |
the stock AFMs can't measure airflow over 450bhp - the car can run over that, but in a sense, your ECU is running blind. You absolutely need an ECU - if you run 2860-5s with the stock ECU, even with a boost controller and keep things at 1 bar (they won't boost lower than that), you will blow a piston at some point - I've seen that exact combination do exactly that. The guy was saving up for the supporting mods but the engine blew up too fast for him, so he had to start all over again, and buy new pistons in the process.
