Old 27th June 2008, 05:27 PM   #1 (permalink)
t78 strengthening
does anyone know of a way of bracing a t78 turbo.as mine keeps cracking the manifold.
safcjo is offline   Reply With Quote
Old 8th July 2008, 01:39 PM   #2 (permalink)
dawgmode's Avatar
buy a better manifold
dawgmode is offline   Reply With Quote
Old 8th July 2008, 02:07 PM   #3 (permalink)
Do you have a support bracket between the downpipe/front pipe and gearbox and do you have a flexible joint in the front pipe ?
Stu
R32 GTR - Godzirra
Twin turbo RB25'd 200SX RS13 - 405bhp and 348lbs ft on 15psi
mambastu is offline   Reply With Quote
Old 19th July 2008, 12:09 AM   #4 (permalink)
x2 its good to have a flex joint somewhere near the downpipe. alot of the heavier turbos i would use bend some aluminum and bolt it to the compressor housing or i would drill one of the bolts and tie it with safety wire to head similar to the way brake rotor hats use safety wire.
seve7 is offline   Reply With Quote
Old 21st July 2008, 07:56 PM   #5 (permalink)
no. use a brace to take the weight of it. even HKS/Trust/Blitz manifold crack like crap all the time if not braced.
hell, even the GrpA GTRs had braces to take the weight on STOCK manifolds.
but still 99% of people dont.
bracing it isnt foolpoof solution, but helps more than anything else you can do.
so such off the shelf thing for a GTR though, all the ones ive seen have been custom, tho its simple enough.
