quick question on the 2860 turbos
alrite gents
was going to go down the single turbo route but its turning out to be too expensive..so ive decided on 2860s...the new engine is a 2.7 just wondering when the following will kick in and what sort of power the below give: 2860-5 2860-7 2860-10 ive got a 2.7 now..with some 280 cams. any info would be great ta |
Too many variables mate...
I've seen 450hp from -7, 600hp from -5, not too sure about -10 (don't know anyone with this set-up) Generally the -5 is a good 500rpm laggier then the -7... But since you have the 2.7 this will narrow it down.. Rb26 Turbo Upgrade, All Dyno Results - Skylines Australia Have a read.. Worth it's weight (if any ) in Gold! Good luck bud |
With the extra capacity and larger cams, which will be most efficient at high rpms, the -7's will run out of puff. -5's would keep it nice and responsive because of the extra cubes, but keep pulling all the way to the redline.
#14 (permalink) |
550 is easy at 1.5 bar - I made 500 at the wheels with a crap conservative map at that boost. With 1.6 and a good track map you'll be closer to 600 at the crank.
I need to start shopping for spare turbos. I estimate about 5000km life left in mine. 20,000km between rebuilds on turbos may seem ridiculous, but then you haven't felt what 2 bars on these are like!! ![]() |
#15 (permalink) | |
Kismet: have you dyno'd your car at 2.0bar? atw? what cams and do you have a modded/ported head? |
