Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > New Nissan GTR R35 > R35 Technical
Old 2nd July 2008, 10:12 PM   #16 (permalink)
tokyogtr's Avatar
Originally Posted by doggiehowser View Post
Last resort: which is what I use primarily: CF slot.
Get a CF card (or an SD card with CF adaptor etc), and drag/drop the MP3s from iTunes to the card. Then plug card into the CF slot on the GTR.
Sounds better than A2DP IMHO
downside is it won't play protected music purchased from itunes though....
Lewis Hamilton, if you're listening, you can drive my GT-R anytime!
Old 3rd July 2008, 02:35 AM   #17 (permalink)
doggiehowser's Avatar
Originally Posted by tomgtr View Post
Yep. Mind you think 30 GB worth of hard disk will do for a while. Blast bunch of MP3's on a cd and move them to the hard disk. I think. I will have to wait another year to try.
I think for the JDM spec, the 30GB HDD is populated with satnav etc and other apps, so the actual space left is 10GB.
As for "ripping" to the HDD, I think it only rips Audio CDs. Don't think it allows you to copy MP3s from a CD to the HDD.
doggiehowser is offline   Reply With Quote
Old 3rd July 2008, 02:37 AM   #18 (permalink)
that's why i said "mp3"
I don't tink they play Apple Lossless either.
Old 3rd July 2008, 07:27 PM   #19 (permalink)
Thanks my dear and lucky GTR owners. Your input appreciated. You guys are the guru's here!
tomgtr is offline   Reply With Quote
Old 3rd July 2008, 09:25 PM   #20 (permalink)
Robbie J's Avatar
it will play MP3's off a CD. It might off a DVD so it needs a test
Robbie J is offline   Reply With Quote
Old 4th July 2008, 01:54 AM   #21 (permalink)
I don't think it plays MP3s off DVDs. Only CD.
Old 7th July 2008, 02:39 PM   #22 (permalink)
Highlander's Avatar
Send a message via MSN to Highlander
It's a pity that UK non satnav cars will still only have 9.4GB (or whatever) available on the built in hard drive which leads me to question the, "you cant retrospectively upgrade to satnav."
I'm sure someone will work out how to reformat the HDD in the system so there is no useless satnav partition on it, after all it's probably on a 2.5" 30GB IDE hard drive.
Highlander is offline   Reply With Quote
Old 7th July 2008, 06:02 PM   #23 (permalink)
charles charlie's Avatar
Surely much easier to just replace the HDD with a larger capacity.
Old 7th July 2008, 06:26 PM   #24 (permalink)
Highlander's Avatar
That depends on how the system is configured to use it as a music storage device.
Old 7th July 2008, 06:59 PM   #25 (permalink)
It should be possible to use a disk image software to copy the partitions across to a larger volume.
Similar thing can be done with a SKY+ box. Mine currently has a 1Tb drive which holds lots of HD films!
I would be very surprised if there wasnt a working method by the time our cars arrive next year!
Old 7th July 2008, 10:32 PM   #26 (permalink)
Robbie J's Avatar
I have a original sky+ box that came with 40GB I stuck a 160GB in.
Its getting into the dash to get the drive out, its all a bit new for my ham fisted screw driver? You can use partition magic to copy the partition and grow it to the size you need to a bigger drive.
I will check the DVD won't play MP3s I will stick limited number of files
R
Old 8th July 2008, 07:42 AM   #27 (permalink)
R
Go on.......
have a go!
Old 8th July 2008, 12:07 PM   #28 (permalink)
Robbie J's Avatar
not while its has the new smell....
purhaps later
R
Old 8th July 2008, 12:21 PM   #29 (permalink)
wimp!
Old 8th July 2008, 05:11 PM   #30 (permalink)
Robbie J's Avatar
I'm happy to accept that :-)
R
