| View Poll Results: valve guide failure? | |||
| I've never had a factory OEM valve guide fail or crack. |
5 | 31.25% |
| I've found one or more factory-installed guides cracked, but no engine failure |
3 | 18.75% |
| I found my guides cracked when they disintegrated into my engine, destroying my block |
3 | 18.75% |
| I've upgraded my valve guides and they are good |
4 | 25.00% |
| I've upgraded my valve guides and they cracked, but no other damage |
1 | 6.25% |
| I've upgraded my valve guides and the damned things broke into pieces, taking out my engine with it |
0 | 0% |
| Voters: 16. You may not vote on this poll | |||
valve guide poll
just another fact-finding thread to try and collect some empirical data...
btw, choice 3 regards losing an engine due to factory-installed OEM guides failing. Last edited by kismetcapitan; 4th July 2008 at 05:43 PM. |
#4 (permalink) | |
I had uprated guides in mine, engine was taken out and all but one of the guides had cracked, lucky no damage was done. Would of made a mess at 2bar boost up the drag stip. Thought while engine was out would refresh bottom end, found two of my main bearing knackered, think the clearences were too tight. Bring on the 2.8 stroker now Work in progress |
When you lift the valve higher you get more valve rock in the guide iron ones
tend to crack because of this thats why you need to use bronze to eliminate this from happening. thanks andy@amt |
RB's don't usually break intake guides but exhaust sides are another story. You should make the poll so that you can tick two options.
I.e. I've never had a guide fail but I've upgraded for the new engine and they're fine. |
