Old 18th April 2003, 10:26 AM   #1 (permalink)
Howsie's Avatar
Question External wastegate
When does it become necessary to fit an external waste gate and are what would be the reason not to fit one?
Howsie is offline   Reply With Quote
Old 18th April 2003, 12:54 PM   #2 (permalink)
hipogtr's Avatar
Generally, you swap to external wastegates when you can no longer control boost well - this happens in high boost applications as the internal wategae springs get forced open by the exhaust backpressure in the turbine housing. If you run greater than 1.4 bar boost regularly you may want to consider the external setup (unless you have a cracker internal wategate spring pressure).
The reason not to fit one would be costs (i.e. they are more expensive) or simply your internal setup controls boost well. Ultimately, the turbo size tends to dictate the need for an external setup or not.
Cya O!
hipogtr is offline   Reply With Quote
Old 18th April 2003, 06:48 PM   #3 (permalink)
Howsie's Avatar
Very helpful. Thanks!
Old 18th April 2003, 09:55 PM   #4 (permalink)
somberg's Avatar
There's another consideration: for a turbo with internal wastegate to lower boost, pressure needs to be applied to the actuator. What happens when a control hose has popped off ? Right, no pressure will be applied, wastegate won't open, boost will go up, damage will be done
With an external wastegate, you can define spring force defining the inlet mfd pressure (or boost pressure if you will) that opens the valve. Apart from that, they feature an input against spring force as well as an input going with the spring force. The pressure of the inlet after the throttle is to go with the spring force and the output of the BCV is to go against the spring force (higher pressure from BCV prevents valve from opening).
This provides for a fail safe system: if the BCV hose pops off, all that happens is that the valve will open at the boost level defined by the spring pressure.
Also, this provides for an advanced way of regulating boost pressure, both on- as well as off-throttle.
somberg is offline   Reply With Quote
Old 19th April 2003, 07:47 AM   #5 (permalink)
Howsie's Avatar
Thanks Somberg!
So in conclusion, its nothing but good news for a external wastegate, apart from the price.
Now where do the exhaust gases go? I have been told that they vent to atmosphere but I can imagine that is slightly illegal but must look/sound good.
Old 19th April 2003, 01:24 PM   #6 (permalink)
Of the appilcation of EW ive seen, a "screamer pipe" is fitted - this vents to atmosphere like you say, but it vents just behind the front passenger wheel. As you come on boost and the wastegate starts to bleed the unwanted exhaust gases off, the noise is incredible!
Matt_S is offline   Reply With Quote
Old 20th April 2003, 02:18 AM   #7 (permalink)
hipogtr's Avatar
Originally posted by Matt_S
...., the noise is incredible!
I can vouch for that in a big way - with two of those suckers in sync!
Cya O!
