Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > New Nissan GTR R35 > General R35 Nissan GTR Chit Chat
Old 6th July 2008, 10:36 PM   #1 (permalink)
minor annoyances
Hi guys,
new member here based in Hong Kong.. Just got a JDM R35 GTR last week and still currently in the break in period.. While I have kept it so far below the recommended rpms, etc the car feels great and is every bit as its hyped up to me.. Just a few minor annoyances I have noticed and was curious if anyone have any solutions to them:
1) The clock is stuck on JP time... I seem to only be able to adjust it by +/1 59 minutes... What do you guys do in time zones much further away? Also, I would imagine after a battery pull the clock would reset and would need to get set again.. How would you do this?
2) The navigation system obviously would not work since I'm not in Japan.. but every so often when I'm driving, the navigation voice would come on saying in japanese that I am about to cross a railroad crossing (when obviously I'm nowhere near any tracks)... any way to turn off the navigation and GPS completely?
3) Fingerprints on the LCD screen is driving me crazy.. Are there any of those screen protector thingies like they have for cellphones and cameras for sale? Or do I have to make my own? Might eliminate a lot of the fingerprints...
4) I have paired my nokia up with the bluetooth function.. making calls is fine.. but somehow I can't set it up to auto answer... everytime a phonecall comes in, it rings once, picks up the call and then immediately drops the call... I have to turn off the auto answer function in the menu and answer manually for it to work... Any solution?
5) Can't seem to get mp3s to play even after burning them to a CD.. system keeps trying to read the disc but doesn't work.. Is there a specific format that the CD has to be burned in?
Also, lastly I was curious if people kept gear in N or 1 at a stop.... when driving a normal manual car, at a stop I would put the car back in neutral and take my foot off the clutch.. seems to be better for the transmission in the long run.. But obviously there is no clutch for the GTR.. so is it advisable to put the car in N or it doesn't really matter when waiting at a stoplight, etc?
Thanks in advance for any advice!
tfung
tfung is offline   Reply With Quote
Old 6th July 2008, 10:55 PM   #2 (permalink)
tokyogtr's Avatar
my opinions below
You can't, too bad.
Just turn off all the voice announcements.
Clean the screen with an anti static cloth as it comes with some sort of coating. after that i found the finger prints would not come back. also, learn to use the jog wheel and push to select.
you're screwed. i have the same problem with my blackberry. nissan confirmed the JDM version has limited bluetooth that was designed solely for use on japan domestic phones.
not had this problem. i burn mp3s from itunes and it works fine.
keep it in 1. manually shifting the box to N everytime will cause unnecessary wear and tear.
Old 7th July 2008, 02:08 AM   #3 (permalink)
Welcome, tfung!
I am actually able to use my Nokia 6110 phone with the car, but not my WM 6.0 phone. The system seems to work with some phones but not others.
What color is your GT-R? Which dealer did you get it from?
golf131 is offline   Reply With Quote
Old 7th July 2008, 02:12 AM   #4 (permalink)
First's Avatar
Now the last question is very interesting that I would like to know as well.
I've got used to shifting to N everytime at a stoplight. I was lead to believe if the stoplight was at a sloped backwards angle, this might put strain on the 1st gear clutch and wearing it out in the long run. I normally put it in N and just pull the handbrakes.
Now which argument is correct? I have no idea now after Tokyo's post since its definately true there's more wear to disengange 1st gear and engage it again.
And I dont have a habit of stepping on the footbrake while on stoplights. I was thought to always put my car in N ever since god knows how long ago I can drive so Tokyo's post really makes me wonder now. Anyone cares to chime in.
First is offline   Reply With Quote
Old 7th July 2008, 02:40 AM   #5 (permalink)
tokyogtr's Avatar
i just feel with the DSG boxes you don't need to shift it to N. and the clunk that it makes seems to indicate there's more wear and tear than just letting the DSG box manage the torque whilst on the brakes at a stop. i could be wrong though...
Old 7th July 2008, 04:40 AM   #6 (permalink)
I do what tokyo says, but my habit's formed from years of driving autos.
tfung - Nokia phones have issues, but some can be resolved. Your issue seems similar to what I was having. Switch off the autoanswer from the bluetooth screen, and change switch off the any key answer on your phone. Delete pairing and redo. Should work. Mine works at least.
timechaser is offline   Reply With Quote
Old 8th July 2008, 04:03 AM   #7 (permalink)
otakki's Avatar
I would just step on the brake at a stop like driving an automatic...I thought it says something like that in the US manual. If not, just pull up enough on the handbrake to prevent the car from creeping forward.
otakki is offline   Reply With Quote
Old 8th July 2008, 04:07 AM   #8 (permalink)
tokyogtr's Avatar
ah ha... turned off the auto answer on the bluetooth screen and it works fine now... good man timechaser...
Old 8th July 2008, 10:25 AM   #9 (permalink)
Sounds sensible, but I personally don't like holding the footbrake on at a standstill as I was once told this was bad news for the brake pads if you've been working them hard prior to stopping.
Old 8th July 2008, 10:43 AM   #10 (permalink)
tokyogtr's Avatar
i don't think you could possibly work them hard enough on the road to matter at a traffic light. on the track though, yes, they get super hot.
Old 9th July 2008, 02:30 AM   #11 (permalink)
Lets put it this way - keeping your foot on the brake is going to wear out the pads, but shifting to neutral and engaging the gear again is going to put pressure on the tranny and the clutch plates. What's going to be more expensive do you think?
Tokyo - Cheers. Glad you got that sussed. You manage to talk to mine's about that gadget yet? Also - does your phone connect automatically when you go into the car? Mine connects, but instantly disconnects. Then I connect it manually and it works like a charm... wonder why.
Old 9th July 2008, 04:11 AM   #12 (permalink)
tokyogtr's Avatar
my phone connects and stays connected. it's even programmed now to retrieve the traffic info via bluetooth for route guidance...
can you pm me about mine's again???
Old 9th July 2008, 08:55 AM   #13 (permalink)
sewid's Avatar
Hi guys,
tfung
They're well annoying and yes they make them for MFD sized LCD's. You can find them on ebay under LCD protectors, just find the right sized one.
Something Cheap and Practical for Your New GT-R
sewid is offline   Reply With Quote
Old 9th July 2008, 03:44 PM   #14 (permalink)
otakki's Avatar
or just get the largest one from your local 100 yen shop and trim to fit.
