yes from what i know it's a 'GR6 dual clutch transmission' heres a list for you;
Model Type - CBA-R35 Transmission - GR6 dual clutch transmission Layout - 4WD Seating Capacity - 4 Dimensions & Weight Length / Width / Height (mm) - 4655 / 1895 / 1370 Wheelbase (mm) - 2780 Tread Front/Rear (mm) - 1590/1600 Indoorsize Length/Width/Height (mm) - 1750 / 1475 / 1095 Weight (Kg) - 1740 Minimum Ground Clearance (mm) - 110 Engine Engine type - VR38DETT Engine - Twin-turbocharged DOHC V6 Displacement (cc) - 3799 Bore x Stroke (mm) - 95.5 x 88.4 Compression Ratio - 9.0 Fuel System - Nissan EGI (ECCS) Horsepower (kW[PS]/rpm) - 353 [480] /6400 Torque (Nm[Kgm]/rpm) - 588 [60.0] /3200-5200 Drivetrain Gear Ratio - GR6 dual clutch transmission 1st - 4.056 2nd - 2.301 3rd - 1.595 4th - 1.248 5th - 1.001 6th - 0.796 Reverse - 3.383 Final Gear Ratio - 3.700 Suspension Front/Rear - Independent double-wishbone/Independent Multi-link Brake Front/Rear - Ventilated Discs / Ventilated Discs Tire Front - 255/40ZRF20 Tire Rear - 285/35ZRF20 Fuel Capacity (liter) - 71.0 |
thank you chamber for the information i appreciated .
im also want to know if its ok , I need some information about gtr,s transmission ( code name ) especially about R31 until R34 , i hope you could answer me . thanks Last edited by jbq; 7th July 2008 at 02:16 PM. |
