Old 7th July 2008, 12:25 PM   #1 (permalink)
glenn gtr's Avatar
oil pressure switch?
Hi i have an r33 gtst with the oil pressure at 5 to six in a morning cold and 2 when warm is this ok. also recently when i drive the car when warm the oil pressure is at 2 then drops to just above 0 and doesnt rise at all, but if i stop the car turn it off then straight back on it goes back to 2 and a half and okay for rest of the time wots going on?
glenn gtr is offline   Reply With Quote
Old 7th July 2008, 06:25 PM   #2 (permalink)
glenn gtr's Avatar
Anybody any ideas.
Old 7th July 2008, 06:52 PM   #3 (permalink)
Redlineash's Avatar
Oil pressure
Glenn,
My R34 GTT has a similar issue. Recently was off the road for a couple of weeks, and suddenly my oil pressure readings are loads lower than they used to be.
4-5 bar at cold, 2-4 when driving around (light throttle to full open), but then when hot can drop to 1 bar.
Ive just got a new oil pressure sender unit from Abbey and should be fitting this wkend - will let you know what happens.
Ash
Redlineash is offline   Reply With Quote
Old 8th July 2008, 12:11 AM   #4 (permalink)
Light-R's Avatar
Send a message via MSN to Light-R
i had that problem.
except that my stock reading was ok.
found out that the greddy gauge oil pressure sensor plug was dirty. crc'd it and it is fine now
Light-R is offline   Reply With Quote
Old 3rd August 2008, 11:26 AM   #5 (permalink)
Redlineash's Avatar
UPDATE
Ok guys quick update.
Fitted the new sender unit and it seems to be working fine, pressure now reads three bar driving gently and between 4 and 5 when pressing on.
only drops to just over 2 when under 2000 revs.
Only bastard thing is that now it looks like my starter motor has packed up....
Old 3rd August 2008, 11:32 AM   #6 (permalink)
Stachi's Avatar
Do you still have the part number of the unit and what did you pay for it? Just out of interest...
Marc
Old 3rd August 2008, 11:53 AM   #7 (permalink)
Redlineash's Avatar
Oil Pressure Sender
I use Abbey to do my servicing etc so just phoned them and they sent me one next day. If i recall it was around £90 delivered give or take a few quid.
part number from FAST is 25070-30P01 for mine but then mine is an RB25 DET NEO from the R34 GTT not a GTR.
I suspect however that they are identical.
Which model is it for and which engine type - Ill look up the number?
Old 3rd August 2008, 12:21 PM   #8 (permalink)
Stachi's Avatar
I'm having trouble with my FAST installation, have to redo it but can't find a reliable source atm..
It is for a R33 GTR. Your help is much appreciated!
Marc
Old 3rd August 2008, 12:22 PM   #9 (permalink)
Redlineash's Avatar
R33 GTR
No worries mate - two mins and ill post it up for you
Old 3rd August 2008, 12:26 PM   #10 (permalink)
Redlineash's Avatar
Oil pressure sender
Its coming up with the same part number as for my R34GTT above.
Hope that helps
Old 3rd August 2008, 12:45 PM   #11 (permalink)
Stachi's Avatar
Thanks for that, searched for a part number for nearly an hour now, maybe I used the wrong keywords, almost drove me mad Cheers
Marc
Old 3rd August 2008, 12:46 PM   #12 (permalink)
Redlineash's Avatar
No worries - if you need any other pert numbers while FAST aint workin for you just PM me.
Glad I could help
Ash
