R35 - Using gear oil as TM oil
I know of a few owner has replaced the TM oil with 75W-140 gear oil, for the sake of lower gearbox noise. So far the only noticeable setback is a higher TM oil temp, can anyone one shed some lights on this ?
Yeap. TM oil is almost like engine oil.
In any case, why not use the original Nissan TM oil? I know even tuning houses like Amuse/MCR use original Nissan TM oil, even if they change the diff/final drive/engine oil to other brands. |
Was told the TM oil temp went up as much as 10 - 15°C, for road use I think its fine but for track I dunno. For zele's oil cooler I think they installed it at the "Hot" spot of our R35, wonder if it helps on oil temp. BTW where to get R35 TM oil in Singapore ? This workshop has another theory, 50% of 10-50 + 50% of 0-30 gives you 5W-40 oil, buy it ?
