IDLE/TIMING PROBLEM
HI GUYS ,
I HAVE A FEW PROBS WITH MY 1990 R32 GTR BASICALLY I REPLACED MY EXHAUST MANIFOLDS TURBO ELBOWS FOR UPRATED ONES AND ALSO TOOK OFF AIRCON AND RECURC SYSTEM BUT NOW EVEN THOUGH ENGINE STARTS FINE IT IDLES AT 1150-1250RPM AND SEEMS TO HUNT TO , TODAY I CHECKED THE TIMING WITH TIMING LIGHT AND AT IDLE THE TIMIMG SEEMED TO JUMP ABOUT A BIT SAY FROM 20 TO 30 DEGREE BTDC MODIFICATIONS ARE AS ABOVE AND NISMO LEMANS TURBOS , ADJUSTABLE ACTUATERS ,HARD PIPES, M S FACTORY AIR FILTER WIDER HOLDERS , K & N AIR FILTERS , TRUST INTERCOOLER , OIL CATCH TANK , 550CC INJECTORS, OIL FILTER RELOCATION KIT, ALL TURBO BRAIDED PIPES, PROFEC B 2 BOOST CONTROLLER, ALLY RAD ,UPRATED LARGE EXHAUST DOWNPIPE AND EXHAUST , ALSO NO CAT (NOT SURE IF 1990 CARS CAME WITH A CAT!) ALSO WHILE TRYING TO SET UP BOOST CONTROLLER ON HIGH BOOST 1BAR I THINK I NOTICED ENGINE PINKING (PRE DET)!! ANY ADVICE WOULD BE VERY APPRECIATED ![]() |
OK I HAVE GOT THE ENGINE TO IDLE AT 900 RPM THIS MORNING BY ADJUSTING AAC VALVE SCREW, THROTTLE SENSOR,AND THROTTLE LINKAGE, BUT IDLE IS STILL HUNTING A BIT ,I CHECKED TIMING AGAIN AND AT 900RPM SOMETIMES IT SITS PERFECT AND OTHER TIMES ITS FLICKING BETWEEN 17 DEGREES AND 23 DEGREES BTDC !
ANYONE ! ANY IDEAS? |
ok firstly you see the button on your key board that says CAPS LOCK yeah, that one, use it!
put all your sensors back where they were. you have a vacum/boost leak, recheck all of your joins and possibly even silicone them then stick the pipes and clamps back on. |
no caps here!
Hi thanks for reply , when you say sencers back it allways did idle a bit fast so i followed the r32 gtr manual on fast idle but i guess that when vaccum leak is fixed it may drop even lower due to me adjusting it ,could the aac valve be sticking/faullty would that cause timimg to jump about? im pretty dam sure ive no boost leak as i renewed all boost pipes and clamps recently quite poss a vaccum leak though as ive also recently took off recurc pipes and put on profec b boost controller , i was going to buy a blazt cable to connect ecu to my laptop do you know if the fault would show up on that? many thanks steve
aac valve
hi, checked aac valve and seems fine also compressed plentum intake to 1 bar by taking out temp sensor and found no leaks ,this is really p**sin me off now lol, still is jumping few degrees and hunting (rpm going up and down) on idle arrrrrrrrrrrrr wheres my big hammer!
