Its a bit of an open ended question, as 500bhp is quite hard to get and sustain without spebding lots of cash. Are you sure you want 500bhp, 400 to 440 ish is ok without to much prob. after that the clutch is going to have problems, the injectors run out at about 400 ish, the air flow meters are on the max. The list goes on. All GTRs should have when in the UK a full map with another ECU for the fuel grage and the restrictot to alow 0.8 Bar boost, with the filters and Exhaust, then you will see 350 to 380 bhp.
thanks for your response
i know i need injectors and turbos would love to find out how many more parts will definately need changing to obtain my goal not worried about the cluch brakes or drive train just need the bare essentials |
MODERATOR
Stage 1 - 400 ish bhp isn`t to expensive, from scratch around 2-3k.
However your going on to a much bigger level. Your best bet will be to get some quotes from the traders on here and decide exactly what you require as mistakes can be extremely pricey. |
