Old 14th July 2008, 04:22 PM   #16 (permalink)
UK_SPAWN's Avatar
Send a message via MSN to UK_SPAWN
Thanks.. Big thumbs up to all.. i have learned things
UK_SPAWN is offline   Reply With Quote
Old 14th July 2008, 05:07 PM   #17 (permalink)
Light-R's Avatar
Send a message via MSN to Light-R
Originally Posted by Nocturnal View Post
600bhp at the fly wheel should be okay with a single Tomei 280l/h in tank pump.
You would want dual entry fuel rail and probably 680cc+ injectors.
720cc would be ideal.
But 600bhp is the edge of what a single fuel pump will provide. I am trying to go for a bit more and it looks like I will need to run 2 intake pump in order to supply the fuel.
this is true.
but i have a greddy fuel press gauge installed after the fpr and even in high boost i never lose fuel press.
but as i said i would advise bigger injectors.
as i said before i run 646hp at the fly and i only have a single 280l pump, 600cc injectors and a sard fpr. my fuel press is high in the whole powerband, and my afr is very rich even in high boost mode.
the mapper has set my rev limiter @ 7200 because of lack of injector efficiency. i could raise it to 8000 but i would be worried as i have 2.7l displacement and "only" an n1 oil pump.
Light-R is online now   Reply With Quote
Old 14th July 2008, 08:20 PM   #18 (permalink)
UK_SPAWN's Avatar
is there any risk of over pressure if you used say, a 280lph pump in the tank, then running to a collector and a external 330lph+ pump... i know its WAY over what i need, but it will give room for more power, and will be run at "less stress" ? do i have the right idea?
Thnx guys n gals
Old 14th July 2008, 09:01 PM   #19 (permalink)
banzai g's Avatar
Run another in tank pump !!!! Was chatting to RB bout this for my r33 gtr !!!! Im running a 280 pump at the moment.
Alot cheaper than swirl pots etc.
banzai g is offline   Reply With Quote
Old 14th July 2008, 10:09 PM   #20 (permalink)
GT-R Glenn's Avatar
Fuel pump and injectors for 2860-5 turbos
Old 15th July 2008, 07:59 AM   #21 (permalink)
Nocturnal's Avatar
Light-R: That sounds about right. That is pretty good that you are getting 646 bhp out of 600cc injectors and a single pump. I got the same problem at the same power with the single 280l/h fuel pump and 680cc injectors.
For 600bhp, a single 280l/h pump will be fine... Just the edge of it, but fine.
Like I said, any more, even if it is 50bhp, you will need a twin pump setup.
WideBody BNR32: Winner of the 2007 Cubism Award!!!
Banzai October 2007 Feature Car / MaxPower April 2008 Feature Car
For Magazine Feature, Wallpapers, Videos, and more...CLICK HERE!!!
Nocturnal is offline   Reply With Quote
