Holset Turbo on RB30
I have only managed to find a couple of threads on here regarding these tubro's but no power outputs or anything.
Can anyone tell me if the HX40 would be a good single turbo to go for on an RB30 conversion?? What boost are they good for and what sort of power could it make? with suitbale cams and supporting mods? What about on an RB26? Thank you Lee |
#2 (permalink) | |
I think HX 40 super is good. It is new model. Hx40 is like a T78 greddy, but cheaper. hx40 super got new wheel technology and spool little bit faster. Compressor map (old hx40, hx40super, hx52): ![]() HX40 with 14-17 exhaust housing is good choice and works good with ~700hp ![]() Last edited by Taiquri; 15th July 2008 at 05:06 PM. |
holset turbos are an unusual turbo for small displacement performance applications. over in the states the hx40 is as an upgrade on the 5.9L cummins diesel found in dodge rams. head over to turbo diesel registry. those guys probably know more about holset turbos than anyone else. my buddy has an hx35 on his ram and makes over 2 bar on a 5.9L engine, so i dont know if you get good flow on a small engine at reasonable boost levels. and hes only making 320hp at the wheels, although its making 700ft lbs of torque.
from experience my friends, and i have never been happy with greddy turbos. i tend to stick with garett turbos. |
#5 (permalink) | |
In finland. Half of the powerfull cars have holset turbocharger. It is very popular here. Hy35 with 8# exhaust housing making easily 600hv ~2L engine. I am planning to put HX52 Pro to my gtr or Precision turbo. HX 52 PRO works like t51 hks (no ball bearings) Last edited by Taiquri; 19th July 2008 at 07:12 AM. |
the pressure ratio is basically the boost. 1:1 is no boost, 2:1 is 1 bar, and 3:1 it 2 bar. this is basically an compressor rpm map. the lines represent the rpm of the compressor wheel. the air flow is usually measured in lbs/min. its supposed to look like a topographical map, showing the adiabatic efficiency for given flow/pressure/compressor rpm. this one is very basic. but it somewhat illustrates the point.
for whats available stateside hks turbos are very rare to see. its so much chepaer to go with a turbonetics, precision, innovative, or garrett, and the service and support is a lot better, with a lot more options and configurations for turbos.
#10 (permalink) | |
Also, read all 3 of these sections: TurboByGarrett.com - Turbo Systems Tech Center |
#11 (permalink) | |
#12 (permalink) | |
