Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Audio & Security
Old 14th July 2008, 01:17 PM   #1 (permalink)
vintoni's Avatar
STEREO HELP!!!!!!!!!!!!!
Hi everyone
I have cd/dvd stereo in my GTR that is pissing me off. It has power as the display lights up but that's all it does. I cannot play cd's, the display screen does not come out and none of the buttons work. It desplays "ent-leve" when you turn the ignition on. Apparently it worked for the previous owner but reverted to the above when the battery was changed. I have since installed a monster battery but the problem persists. Any ideas? I have a grounding kit ready to be fitted but not sure if this will make any difference. The manual says "ent-leve" has something to do with the voltage being in the wrong range?
Any help would be greatly appreciated, I don't want to have to pay to get it looked at as I'm a struggling GTR owner .
Thanks
vintoni is offline   Reply With Quote
Old 14th July 2008, 01:53 PM   #2 (permalink)
ru'
ru''s Avatar
Just to test it, run a length of wire direct from the battery +ve to both the +12V and 'switched 12V' lines. Make sure you've got a decent earth on the HU too.
If it works then either your main feed or switched feed are duff; try them one at a time to find out which.
Old 14th July 2008, 01:58 PM   #3 (permalink)
Before doing that try swapping the permanent and switched 12v feeds round, my clarion would do something similar til I switched them
Hang on, when you say it worked for the previous owner but started giving the ent-leve error message after a battery change, do you mean after he changed his battery or you changed yours?
He might have killed it you see!
Old 14th July 2008, 02:54 PM   #4 (permalink)
vintoni's Avatar
After he changed his to a shitty little battery.
It kept going flat on me so I then changed it again to a bigger one but the "ent-leve" message remained.
Old 14th July 2008, 03:02 PM   #5 (permalink)
Chances are the low voltage could have killed it, it will try to pull more current as the voltage drops (this is the quickest way to kill a car amp btw, mucho smoke/flamage )
Best way to check is get a working battery, and as ru said, hook the head unit up directly to it ie positive terminal to the 2 12v inputs, and the negative to the earth
If it still doesn't work, the low voltage from the previous battery killed it
Old 14th July 2008, 03:08 PM   #6 (permalink)
vintoni's Avatar
Sh1t
Old 14th July 2008, 03:09 PM   #7 (permalink)
vintoni's Avatar
But if it's fried how come it still lights up and gives a code?
Old 14th July 2008, 03:20 PM   #8 (permalink)
It could just be part of it thats damaged, like I said only way to know for sure is to hook it up directly to a battery
If it does work then get a multimeter out and see what voltage the radio power wires are showing
Old 14th July 2008, 03:26 PM   #9 (permalink)
vintoni's Avatar
I'll get on it. Thanks for your help, appreciate it.
Old 14th July 2008, 06:04 PM   #10 (permalink)
SPEED MERCHANT's Avatar
Send a message via MSN to SPEED MERCHANT
Give Tony at Eclipse Car Audio a call on 07834 158795 fella & say that SPEED MERCHANT gave you the number
He does all my audio stuff.
ズピード マーシャント
GTROC E-LINES EDITOR
GTROC LONDON REGIONAL REP
GTROC BEST R33 'RUNNER UP' 2007
GTROC SOCALITE OF THE YEAR 2008
GTROC NATIONAL EVENTS COORDINATOR
TEAM NITEWING PROUDLY SPONSORED BY "JAPSALON" , "MeisterR", ECLIPSE CAR AUDIO" & "ATEUK"
THE "HOLY PHOTOGRAPHS" COVETED "BAT PHOTOALBUM" !!!
SPEED MERCHANT is offline   Reply With Quote
Old 15th July 2008, 01:02 AM   #11 (permalink)
pupsi's Avatar
Is it a coded unit?? When you changed the battery, you then have to enter a code, if it is a coded unit.
Old 15th July 2008, 03:25 AM   #12 (permalink)
beaumackenzie's Avatar
meh, who needs them just rip out and put a big bore on the car.
Old 28th July 2008, 02:41 PM   #13 (permalink)
covak2002's Avatar
RIP IT OUT and place it on a bat outside of the car but remember to place an earth to the chassis of the stereo and see what happens my fault was down to a wiring snag on the car quick rewire and well rocking all over the world
try that mate
covak2002 is offline   Reply With Quote
Old 28th July 2008, 08:04 PM   #14 (permalink)
DUNCAN GT-R's Avatar
Check that it's got a good earth on the black wire. The skyline doesnt have an earth wire in with the radio loom, it relys in the radio chassis being bolted into the dash for an earth.
Run the black wire off the radio to a good earth point, usually you can find a 10mm bolt onto the chassis behind the radio.
DUNCAN GT-R is offline   Reply With Quote
