turbo oil feed question?
can anyone help? i have a bearing failure on my hks 2530 turbos so i am swapping turbos to garrett 2860-5's my question is:- the 2530's use an oil restrictor do i need them for the 2860-5's
r32 gtr thanks shane |
TurboByGarrett.com - FAQ's
0.040" I think this is about 0.8mm . I have 1.0mm ones on my HT2510´s , and seems like the turbos use a little bit of oil . It depends on oil pressure . As I have pretty high pressure I probably need smaller . I now make the restrictors with 0.8mm instead of 1.0mm . ATP versions are also 0.8mm . |
-4 size Oil inlet fitting for GT28/30/35R with built-in restrictor: atpturbo.com
0.035" ............ ATP . |
