Old 20th November 2008, 09:07 PM   #11 (permalink)
The Enoch
Aluminium driveshaft
This is standing under the aluminium driveshaft product on Driveshaft shops website:
"The aluminum shaft has many advantages over the carbon steel shafts that most people are not aware of. The most obvious being the fact that it is 1/3 less weight, but the other thing that makes it attractive is that its resonant frequency properties are much higher. What this means to you is that a steel shaft may amplify a vibration where an aluminum one will dampen a vibration. The other thing is that an aluminum shaft torsionaly twists 19 degrees and a steel shaft only twist 5 degrees. What this means to a hot rod is the shaft will have a more dampened effect taking the shock load out of the drivetrain, making it more fluid feeling. Shafts can be made to handle power from mild to wild."
The Enoch is offline   Reply With Quote
