#46 (permalink) |
You need to use the twin cam ones from memory, i used rb20/25 arp head stud kit, a couple of mates have re-used stock rb25 ones with no problems, but i would advise at least getting new ones.
#47 (permalink) | |
If you want to use studs, get arp RB25 head studs. An article on a R32 GTS4 we built about 4 years ago has just come out in NZ performance car magazine, I'll scan it and add it on here when I get a chance. We ran 10s in it straight away with a stock RB30 bottom end, stock R32 RB25de head, stock bolts, stock gasket, stock N/A cams and springs etc and its been running 10s ever since while still doing huge road miles, dyno comps and track days. The guy I built it for sold it about a year ago, the new owner freshened the motor, did some head work and he's running reliable 10s also, I think he's just beaten the times we got in it. Rob
#48 (permalink) |
#49 (permalink) |
Thanks for the info and the article Rob..
I have already got a power FC ECU.. And have budget for the mapping! Just the build I need to sort out first! I am hoping to get my motor out and stirpped down in the next month. Then when I know where I am with my current engine and what I can salvage I will get a build list together of my intended mods and parts requirements and see what you all reckon! Lee |
#50 (permalink) |
Hi Guy's after a bit of turbo info!!
Would R33 GTR Turbo's rebuilt with steel internals be a good starting set-up for a standard RB30 bottom end build. With cams and other supporting mods could I still get up around 600bhp on these turbo's?? Just thinking of my options to work out my total budget requirement! Thank you Lee |
#52 (permalink) | |
We've had a full weight street R32 run 11.0 with modified stock twins on a RB30 and it was awesome on the road, super responsive but a 'little' flat up top. It all depends on your budget and what your trying to achieve but personally I'd go with a good medium sized single if possible. Rob
#53 (permalink) |
For the price of rebuilding your stock turbos buy a Holset diesel truck turbo (HX40- cheap) and a twinscroll manifold, make way more power and have excellent driveability. Or save and buy a proper set of twins or an expensive single.
#55 (permalink) |
Thanks guys.. Well I just miised out on a cheap set of uprated twins!! Never mind I would prefer to go the single route anyway. I am kean to get a Holset and be a bit unconventional! ON that note does anyone know about the HE500 range compared to the HX40 range> I am guessing the HE500 is probably closer to the HX50 in which case to big for what I am lloking for? Any info gratefully recieved though! The turbo I have found in particular is an HE551V.
Thank you Lee |
#57 (permalink) |
Hi Guy's,
Have been on holiday and trying to tie up a few things. I think I have got an RB30 block sorted.. However as earlier in the post it was agreed the non turbo series 2 block was fine to use with standard pistons someone else has just mention to me that the turbo block has addition oil squirters in it?? I presume these are for cooling the pistons?? Can you mod the standard block to fit squirters or should I not need to?? Its not anything that has been mentioned before?? Also as the compression ratio will obviously be higher running the standard pistons would it be adviseable to run a thicker headgasket like a 1.6mm maybe to drop it back a bit?? Thank you Lee |
#59 (permalink) |
Thank you!
That puts my mind at ease a bit!! I figured someone would have mentioned quite a major point like that before if it was necessary!! So What about running a thicker headgasket?? Good idea?? Cheers Lee |
