Old 16th July 2008, 05:38 PM   #1 (permalink)
brett21's Avatar
Send a message via MSN to brett21
Not as quick as she used to be,,,
I have noticed my 32 GTR is not as quick, its 455hp @F & she was quick, i have 2 settings on the Power FC, 1.15B & 1.20, its now seems quicker on lower boost
also the idle has gone up to 1000 rpm, (air con off) it was bang on 950/75.
Last month it would hold back with 2 people in the car with luggage, it felt like the coils, it has very low mileage Trust 8 plugs, i have ordered a set of Split Fires from Newera, hopefully here this week,
I had a good spray with WD & Brake cleaner a round the vacuum pipes & inlet manifold/ injectors & no movement on the rev's,
Has any one else got any ideas for me to check?
brett21 is offline   Reply With Quote
Old 16th July 2008, 07:05 PM   #2 (permalink)
kismetcapitan's Avatar
try resetting your boost settings. Change the duty setting, and you'll see the "255" in the far right column go back to, well "255". See if that doesn't help add some spark - the Power FC always boosts hardest at the beginning of the self-learning cycle. The more it learns, the softer the boost hits.
Old 17th July 2008, 05:58 PM   #3 (permalink)
brett21's Avatar
I think you may have hit the nail on the head!! Cos i have noticed those figures have changed to what they used to be, but i dont know what they were? It used to have only 2 settings now has 4! What should the duty setting be?
Old 17th July 2008, 11:54 PM   #4 (permalink)
if you were happy with it before, just change it to something random, then change it back. The Power FC will reset the self-learning as soon as you change the duty, even if you return to the original value.
Then take her out for a run and see how it goes!
