there are two det. sensors mounted on the block, under the inlet plenum. i think these are piezo-type transducers, so generate a voltage proportional to incident movement/vibration. they will give a more pronounced "spike" if/when det. occurs, which is fed to the ecu. you're right regards the timing.
Thanks Pete..So i guess then that the ECU i have must of been mapped some how in japan. I will see if there is anything written on the case that gives me some idea who chipped it . The only info i have from Marc@ Topspec imports is that it is a stock ecu with a good map on it .
sorry for butting in and excuse my ignorance about petrol choice, but does the ron rating make that much of a difference? i simply thought it basically affected how susceptible the engine is to knock when caned. am i right in thinking that higher ron fuel burns slower than that of a lower ron, so for the same ignition advance knock it reduced (or removed)?
the stock ecu has some degree of self learning in that it can alter the ignition timing according to the knock signal it receives. i thought that if you regularly use "normal" fuel and have reset the ecu's learned setting then you'd be ok. please tell me if this it utter b0ll0cks. |
Utter B.S.
The ECU can't pull timing until it actually detects knock, which means the engine has ALREADY been run with too much timing, for at least a few revoltions, which can be enough time to kill the engine. It's adaptive learning, not precognitious. once the knock has been detected, the ECU goes to severely conservative timing #'s which generate high EGT and make less power than the correct amount of advance. standalone ECU's are a necessity if you want your car to make power and/or be reliable. Yeah the old adage of 'Fast, Cheap, Reliable' is in the corner of both Fast and Reliable. |
