#17 (permalink) | |
#19 (permalink) |
I would consider the Hondata system a chipped ECU since originally you had to run a ROMulator and burn an eePROM. Hondata just developed their technology to the extent that they have a daughterboard situated inside the ECU which stores data and programming. I consider it a standalone since it is fully programmable unit that has raw input and raw output, not a pass-through fooler unit.
#21 (permalink) |
Has anyone downloaded the base map, if so does it indicate max value for boost,rpm,load( fuel maps only )?I good piggyback installed/ tuned correctly will do for me as long as i'm not on the limitations of the stock ecu.
#22 (permalink) |
The stock ECU is limited to a stock car. If you modify the car you have passed the limitations of the stock ECU unless you modify said ECU to accept new programming. Do you not believe what I am telling you? I realize I only have 4 years experience with programmable EFI and mapping cars, and there are many people out there with 2, 3, 4 times the experiance and a thousand times as much knowledge as I do.
How much experience and knowledge do you have to tell me that I am wrong? |
#23 (permalink) | |
If you install a manual boost controller and do not alter the stock ecu. You turn the boost up and the ecu will cycle to high levels of the map.how high will the fuel map go before the airflow meter maxes out. The original question was out of interest but when answered by people like you, my interest has soon disappeared. |
#24 (permalink) |
You are saying I am wrong when, after I have provided a lot of good, factual information, you say things such as: "I good piggyback installed/ tuned correctly will do for me"
I write correct information. I have shared my experiance. I have tuned cars with SAFCs and seen cars with eManages and other so called good piggybacks blow up because they are garbage. the stock ECU is mapped as high as the stock AFM sensor range, which is about what the stock turbos are good to before they break. Zoltarc already posted this and he is correct to the extent of my knowledge. Around 400whp worth of air. |
#25 (permalink) | |
If your going to be all 'factual' then i would expect a better answer than around 400whp. I new that before i read the post. You dont understand the question or the cars you are tuning. Why dont you say that the air flow meter maxes out at a set voltage on a skyline? because you dont the facts. You should know the range of measurement that the stock ecu uses, if your a professional tuner. So what break horsepower does your skyline run? and what setup are you using? you must have it running really well. |
#26 (permalink) | ||
I'm not aware, Paul, of any scientific studies done to accurately measure the number of people who have a well running car on a piggyback versus the amount of people who have melted a piston, versus ran lean, versus _____. If you have any scientific studies showing the benefits and magic that a piggyback is able to work, then I'd love to see them. Until either one of these massive studies gets underway, I'll continue to use my knowledge of how EFI systems work and how piggybacks function and communicate with stock ECU's to guide my selection of automotive computer electronics. Quote:
If you want to continue to insult me and say things like "You dont understand the question or the cars you are tuning" and ignore the facts I've presented then there is no reason for me to continue posting in this thread, best wishes, I look forward to seeing your "Engine rebuild" thread after the installation and "tuning" of your AFC and subsequent detonation due to high timing advance #'s. If you want to ask pertinent questions and pay attention to the answers, I'll keep posting, and I'd appriciate an apology for insulting my intelligence (which really ticked me a lot, coming from someone who can't even spell "knew" correctly.) Read my posts. You'll find that although I am straightforward and blunt I don't insult people until they (and even then, only sometimes) insult me first. I present factual information. I seek to destroy myths and end speculation and misinformation. If my answers piss you off, frighten, or offend you, then "perhaps you should cease asking scary questions." Last edited by SamuraiSam; 22nd July 2008 at 04:40 AM. |
#27 (permalink) |
Spelling? do you think i care about that at 5 am in the morning. Regarding timing advance and detonation, i'm sure my tuner who has more experience than you will have that area covered.You go on alot about how the piggyback ecu is harmful to the engine, doesn't that come down to the person who tuned it. Maybe the ones you fit melt pistons.
The mods should delete this whole post as none of it is useful. |
#28 (permalink) | |
No, it doesn't come down to the person who tuned it. You really don't know how piggybacks work? Your continued ignorance on this topic even when presented with the facts is astounding. Your inability to understand the subject matter does not make this post useless.
Here are some words straight out of the mouth of a "Professional" who used to post on this messageboard and is still active on FreshAlloy's GT-R forum. Beyond The Dyno » Piggyback ECUs are Bad for Your Health From Eric Hsu, Beyond the Dyno Quote:
