plastigauge sizes for main and rod???
starting to rebuild my rb26dett, crank has been done and is standard bearing size, does any one know which size gauges i need?
if i stab in the dark it's 0.020/0.039mm clearance so the plastigauge is should use is 0.018/0.045mm??? like ebay item 310071473399 could really use some help ![]() |
or do what my builder did and use both micrometers and plastigage.
He used 0.038mm clearances on both crank and rods, and went to great lengths to fit the bearings to those exact clearances. |
I am in luck i have about 5 dif sets I can use from work, (As long as I bring them back :-) but it is complicated and easy to make a hash of it. I have to change range fittings for the internal stuff, and mic the internal guage with the external one as a calibration. all our stuff is checked every 3 months , I am about to build my own engine , I will use mic as realy the plastic is only a guide but its better than nothing. RB engines are highly stressed , as somone else has said its not an uncle Festa!
#9 (permalink) | |
Brilliant, can I borrow a magnetic mount dial gauge for the evening ? can pick up and return same day ! cheers cokey |
I would never let precision measuring tools out of my own sight, and would probably prefer to measure myself. Drop them once, and you have to have them sent out and calibrated. Starrett mics and inside bore gauges are extremely expensive. You do not need a dial gauge to measure main or rod journals, just a set of mics.
