Old 2nd August 2008, 12:35 PM   #1 (permalink)
Peter GTR32's Avatar
Turbo shuffle again
Hi can someone please help to answer how to solve the turbo shuffle I got in my car. I had the shuffle also with my old setup GT-SS turbo's but not so much as now with 2860-5 and remapping. I'm running Greddy hard pipe kit, D-jetro, Apexi air filters open dump valve
1. Can something be damaged cause of this shuffle?
2. What to do to get rid of this shuffle?
Is it caused of bad mapping or different adjusted waste gates or what could it be?
I have searched and read some different threads about this but cant really find out what it could be with my set up?
Most of the others run with AFM:s and std Twin turbo pipe
Peter GTR32 is offline   Reply With Quote
Old 2nd August 2008, 12:59 PM   #2 (permalink)
kismetcapitan's Avatar
it can be argued, but I believe shuffle can help wear out turbo bearings. However, some people don't use BOVs at all, and their turbos are fine. So I'd consider it more an annoyance than anything else.
IIRC, I corrected my shuffling during cruise by adding some more fuel to the injection map. Well, I can't remember exactly what I did, but remapping the problem areas pretty much got rid of 90% of shuffle. I only had it at part throttle on the highway anyways.
Old 2nd August 2008, 04:38 PM   #3 (permalink)
Ian C's Avatar
you can fit a modified twin turbo pipe, helps with shuffle quite a bit.
I'm currently doing a deal with the GTROC shop to make them available ASAP!
read this thread:
Testing modified Twin turbo pipe page 3 shows the part in discussion!
Ian
+10 extra bhp for £55....
Get your baffled TWIN TURBO pipe now from GTR.co.uk Shop
Ian C is offline   Reply With Quote
Old 2nd August 2008, 06:43 PM   #4 (permalink)
read this thread:
Ian
Ian I run with Greddy hard pipe kit and it shouldnt be a problem or?
Old 2nd August 2008, 06:48 PM   #5 (permalink)
UKPAISLEY's Avatar
I would think that adjustable actuators would help, this is the reason I have some, it allows the turbos to be balanced while the wastegate opens , and allows the opening time to be adjusted.
Old 2nd August 2008, 06:53 PM   #6 (permalink)
aren't most actuators adjustable, and I was thinking of posting a thread - setting actuators so that each turbo is perfectly in sync with the other seems to be a neglected step. God knows it's not the easiest thing to do, but it's not any harder than degreeing cams. Just tedious is all.
Old 2nd August 2008, 06:57 PM   #7 (permalink)
UKPAISLEY's Avatar
I havent done a search on it yet, but most standard actuators are just a solid shaft, cost I suppose. The setting needs to be low enough to open before youre desired boost, but not to low as to make the duty cycle of the boost sol work over time. My setting is going to be about 4 PSI below the boost set point.
Old 2nd August 2008, 08:55 PM   #8 (permalink)
Yes the actuators is adjustable on my 2860-5 but I think it could be little tricky to do this. Need double boost gauges but could be hard to have a look on both in the same time
Old 2nd August 2008, 08:58 PM   #9 (permalink)
UKPAISLEY's Avatar
Dosent help much but I intend to "tune" mine off the car, and fit later. All You ould need to do is adjust one a little and see if it makes a diff. Just keep note of how many turns.
Old 3rd August 2008, 12:34 AM   #10 (permalink)
jaycabs's Avatar
Send a message via Yahoo to jaycabs
i had very bad shuffle ages ago making it a nightmare to drive when changing gears but then i let rk tuning remap my car and honestly it never shuffled once again
jaycabs is offline   Reply With Quote
Old 3rd August 2008, 01:15 AM   #11 (permalink)
pupsi's Avatar
What about installing a balance pipe?????
Old 4th August 2008, 01:06 AM   #12 (permalink)
frostmotorsport's Avatar
so.... by modifying the "twin-turbo" pipe to remove shuffle (which is something I'm now contemplating) - does this remove the wonderful noise that the BOV's make chattering to each other on light-throttle gear changes? cos I wanna keep that and on-throttle shuffle is not really a problem in my current tune....
Old 4th August 2008, 05:49 AM   #13 (permalink)
GT-R Glenn's Avatar
Where did you get that from ?
The balance pipe goes between the exhaust manifolds.
Should be able to tune shuffle out.
Old 4th August 2008, 07:16 AM   #14 (permalink)
Ian C's Avatar
I made one myself as part of rebuild this year (check pages 4 & 8 of the link in my signature)
Hoping to get them in the GTROC shop within August (on an exchange basis)
Ian
Old 4th August 2008, 08:23 AM   #15 (permalink)
UKPAISLEY's Avatar
Even with a balance on the exhaust side, ie the input gas, if the actuators are not matched then the turbo will respond diff according to boost pressure ?
