Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Audio & Security
Old 4th August 2008, 11:48 PM   #1 (permalink)
Ignition wires for r32 alarm
Hey, ok i have ran into huge trouble. i am installing an alarm and auto start and need to splice into the ignition wire. there is 5 wires coming from the ignition switch and the colors are black with white stripe, black with green stripe, black with yellow stripe, white with red stripe, and solid blue. does anyone know wich wire it could be i have been playing with it for months and it seems none of them are the one !
gordooo is offline   Reply With Quote
Old 5th August 2008, 03:52 PM   #2 (permalink)
DUNCAN GT-R's Avatar
Test them with a multimeter or a test light.
DUNCAN GT-R is offline   Reply With Quote
Old 5th August 2008, 05:10 PM   #3 (permalink)
Question
ya i have tried that the problem is i only found one wire the is positive 12v (almost 12v ) during cranking but wen i clip the wire the car still starts up fine !
Old 6th August 2008, 11:42 AM   #4 (permalink)
the ignition wire you say you are looking for, will come live when you turn the ignition on.
There will also be a permanent 12volt wire, an accessory 12 volt wire, and the starter wire.
Old 6th August 2008, 03:50 PM   #5 (permalink)
So the ignition wire will show 12v+ not only when the car is cranking but also a stage before that?
Old 7th August 2008, 09:25 PM   #6 (permalink)
Yeah, it'll show 12 volts when the ignition lights come on, and also while the engine is cranking.
Old 7th August 2008, 10:03 PM   #7 (permalink)
found all them, reason for all the trouble is there is 2 starter wires
Old 9th August 2008, 06:31 PM   #8 (permalink)
Not on mine there wasn't. !!!
