Removing manifold nuts?
As some of you may know i was having a problem with a strange rattley sound on my R32 GTR, got worse on thursday last week and on friday night a gasket (either manifold or turbo to elbow gasket) let go with a rather frightening roar!
Now in the process of stripping the turbos, manifolds and anything else that gets in the road off. Rather scary but theres only one way to learn......right? Going to change all the gaskets (manifold, turbo to manifold, turbo to elbow gaskets) and replacing the downpipe with a HKS one and a decat. Going ok till i reach the lower manifold nuts, OMG no room at all, no way i can get a rachet in, got a half turn on the first one with a spanner but cant get anyware near the next two, never mind the rear manifold! Has anyone got any tips or hints on how to get the little feckers off? Have been using biggies guide (top work!) but have really hit a wall hear! Please help! |
ADMINISTRATOR
AFAIK you need to cut a spanner in half to get it down there.
or, use universal jointed sockets mook
FOR ALL GTR FORUM RELATED ISSUES CONTACT THE ADMIN TEAM 'MOOKISTAR' OR 'MOLEMAN' SKYLINE FAQ'S! |
You can remove the turbo's inlet pipe, that will give some more room. The remove the turbo from the manifold and lower it down, then WD40 all the manifold nuts and crack them off with a ratchet and extension bar.
Have fun ![]() Smokey ![]()
It's all about driving a race car on the street !!! 10.59@133 mph TOTB Handling 52.026 sec Snetterton Super Battle 2008 "No story sits by itself. Sometimes stories meet at corners and sometimes they cover one another completly, like stones beneath a river" |
#5 (permalink) | |
GTR abuser
PS: one socket(14mm,1/4size with joint) is around 45GBP ![]()
_____________________________________________ March.06 --->R34GTR V-spec,my first GTR arrived March.07 --->R34GTR V-specII,a dream came true March.08 --->R35GTR,the order is placed March.09 --->R35GTR should arrive |
Will try dropping the turbos was trying to get in with them still on their braces! doh!
The Snap-on stuffs really tasty but the price is shocking! Thanks for the help so far troops Will keep u posted! ![]() |
as said.
lower the front turbo and fit extension with soket through the gap, you can also moove the power steering pump to one side, but i prefer the ratchet idea, as thats the way i did it, second turbo you dont need to lwer it, just fiddle with a spaner as there will be no turbo infront so will be ..."easier to access". not a fun job good luck |
GOTCHA!
![]() ![]() What a feckin nightmare! Finally got the front one off! Didn't relise there was so much to disconnect to get these buggers to move. Managed to get to the bottom manifold studs by getting the turbo as low as possible then getting in with a short ratchet. Longest job was taking off the rear oil return feed, almost impossible to get a spanner on and got about an eighth of a turn each time. Took an hour just for that!! Hope i havent bent the lines too much! ![]() Anywho! Hopefully get the back one off Sunday. Battered fingers crossed! ![]() |
#10 (permalink) | |
The following advice was invaluable when I did it:
April 22nd 2007 How many hours for a turbo swap? - FreshAlloy.com Forums Quote:
