Old 14th August 2008, 02:00 PM   #1 (permalink)
Tomei Cam Question
Is it necessary to have to buy the Tomei lifters when you buy the Tomei cams with 10.25 lift? Would using the stock lifters be ok?
max power rb is offline   Reply With Quote
Old 14th August 2008, 02:42 PM   #2 (permalink)
Andy_P's Avatar
I hope not....I've just bought the Tomei poncams....tuner guy didn't mention about buying them....but that's a gtst....yours might be a GTR of course.,...then it's all different
Andy_P is offline   Reply With Quote
Old 14th August 2008, 03:27 PM   #3 (permalink)
Alecci's Avatar
I was told that I needed to upgrade the lifters when going above 9.25mm lift. They also recommend that you upgrade the valve springs as well.
Alecci is offline   Reply With Quote
Old 14th August 2008, 03:31 PM   #4 (permalink)
sorry that i didnt mention, its for a rb26dett r32 motor, anyways some people say its recommended some say its a must. i dont feel like spending that extra $400 if i dont have too.
Old 14th August 2008, 08:05 PM   #5 (permalink)
You must buy the Tomei lifters, to get the extra lift the cams are ground with a smaller base circle diameter, which means you need lifters with added depth between cam lobe pad and shim extension. The higher lift Tomei cams need the cylinder head machining to clear the cam lobes, too.
Old 14th August 2008, 08:09 PM   #6 (permalink)
kismetcapitan's Avatar
true, but with Poncams no mods are necessary, although uprated springs can't hurt. I think the lift, 9.15mm, was chosen because it's the max you can get without having to modify the head or buckets, etc.
Old 14th August 2008, 08:10 PM   #7 (permalink)
UK_SPAWN's Avatar
Send a message via MSN to UK_SPAWN
id listen to him, something that complicated must be right .. hehe no but seriously .. buy them! its an extra $400 or probably something a lot more expensive when things go wrong..
:edit: maybe nothing will go wrong then but still ...
UK_SPAWN is offline   Reply With Quote
Old 14th August 2008, 08:34 PM   #8 (permalink)
cokey's Avatar
They are not manditory... but if you are going to use all or more of the revs , then for peace of mind they may be a worthwhile investment.
see now I'm convinced.. Group buy folks ?????
Old 15th August 2008, 01:22 AM   #9 (permalink)
oh well whats another 400 dollars when i already spent 10,000
Old 15th August 2008, 04:26 AM   #10 (permalink)
SamuraiSam's Avatar
There is a lot of completely incorrect information in this thread. Kismetcaptain is right: Only use the Tomei lifters on Tomei Procams which have a smaller base circle than stock. With Poncams (Stock base circle) the stock lifters are what you need to run.
Old 16th August 2008, 09:41 AM   #11 (permalink)
R.I.P.S NZ's Avatar
What he said ^^^^^^^^^
R34 GTR: Quickest full street trim skyline in NZ, 9.7 @ 137 on 1st test pass, first meeting in the UK, 10.4 @ 144.
RIPS 240z, WRH8.36 / 163 @ 1.9 bar, stock crank, stock block, petrol
RIPS 240z, RIPS RB30, quickest/fastest Jap street car in NZ 8.36/163mph 1.9 bar. NZs quickest Pro Import on petrol.
e-mail rips@inspire.net.nz
www.ripsracing.com
Old 16th August 2008, 11:01 PM   #12 (permalink)
GT-R Glenn's Avatar
PON cams are designed as a straight drop in cam.
And as such use stock base circle, like Sam said.
Old 17th August 2008, 11:07 AM   #13 (permalink)
AFAIK all Tomei RB* cams with 10.25 or more lift are small base circle and need the extended followers in order not to need ludicrously thick (and thus none stock size) shims.
Old 18th August 2008, 03:13 AM   #14 (permalink)
SamuraiSam's Avatar
Yes, those would be called Procams which I mentioned in my earlier post I guess they have models of Procam that seem to have the same specs as the Poncam (the 252° and 260°) which have std. base circle diameter so you are correct the 10.25 and up.
