Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > New Nissan GTR R35 > R35 Technical
Old 19th August 2008, 04:56 PM   #1 (permalink)
things need to be done during first service?
I dont understand why is it so complicated to find out what needed to be done during first oil change????
at 1000km engine oil and filter change
at 6000km engine oil and filer, air filter, gearbox oil, plus differential front and rear
after that every 5-6000km
Am I Correct?????? Thanks in advance
Its getting so confuse
Winsome
winsome is offline   Reply With Quote
Old 20th August 2008, 11:42 PM   #2 (permalink)
tokyogtr's Avatar
it's all listed in your maintenance book but if you want to see the US version go to page 24 here: http://www.nissanusa.com/pdf/techpub...09_GTR_SMG.pdf
Old 21st August 2008, 06:19 AM   #3 (permalink)
so no oil change at 1000mile service then..........well i suppose that answers the question also about whether they use a different "running-in" oil at the beginning
axolotl is offline   Reply With Quote
Old 21st August 2008, 06:51 AM   #4 (permalink)
you should change the oil every 3500 miles.
Do you know why the GT-R requires Synthetic 0W40 with a short change interval?, Highlights of my conversation with a Nissan design engineer
1. Plasma lining
2. More importantly....lubricating the turbo bearings that spin at 20-100K rpm
Yes, the engine oil cools the turbo bearings, for which 0W40 at every 3500 miles is a treat.
Think twice before you decide to skip that oil change and kudos if you ran the engine hard and changed the oil early.
someone replied...
Just like to point out, for the GTR owners new to turbo cars, that almost all turbo cars I have owned operate the turbos between 20,000-120,000 rpm. All the Subarus (that are turboed) operate the turbos in this range (or higher - example if you live at higher elevations). Subaru requires oil changes every 3750 miles for turbo models with regular dino oil.
Just wanted to point that out so someone who saw that rpm wouldn't think 'Wow the GTR's turbos spin SO fast, faster than normal...'
this was from nagtroc
