Old 20th August 2008, 01:39 AM   #1 (permalink)
vettekiller's Avatar
Send a message via MSN to vettekiller
R34 NUR ENGINE TO R33GTR.!!
just bought a nur r34 engine to fit a in my R33 GTR~
I KNOW that i have to use, sump and differencial of my r33gtr , and change the CAS??? what they differ??
but r33 plug will fit on r34 cas??? if yes what i have to re wired so i can make it work and start this engine??
please someone with specific details to put this engine in a r33 gtr.!!!
thanks
jeffrey
vettekiller is offline   Reply With Quote
Old 20th August 2008, 02:17 AM   #2 (permalink)
Send a message via MSN to Mashrock
use your 33 cas on the 34 motor.
the diff, and thats about it really.
... i think..
Mashrock is offline   Reply With Quote
Old 20th August 2008, 03:21 AM   #3 (permalink)
I HAVE READ THAT R34 WON'T START WITH R33 CAS?? WHAT I HAVE TO DO, WITH DEATAILS.
JEFF
Old 20th August 2008, 03:23 AM   #4 (permalink)
tyndago's Avatar
1 and 120 signal.
Old 20th August 2008, 03:27 AM   #5 (permalink)
Originally Posted by tyndago View Post
1 and 120 signal.
?????? hmm can you explain yourself
jeffrey
Old 20th August 2008, 03:29 AM   #6 (permalink)
tyndago's Avatar
Thats the difference. You need to swap around the 1 and 120 signals. If you look at a wiring diagram for an R33 ECU, and R34 ECU you will see they come in on different pins. Swapped pins.
I have swapped them back and forth on cars with different combinations.
Old 20th August 2008, 03:33 AM   #7 (permalink)
so i can used my r33 gtr cas, just i have to swap the signal?? can you tell me how??? o got the service manual of the r33 not the r34/
please thank you for helping me
jeff
Old 20th August 2008, 04:24 AM   #8 (permalink)
tyndago's Avatar
R34 Service Manual - Nissan Skyline GT-R s in the USA Blog: Nissan R34 GT-R Service Manual in English
I will have to find my notes, and put them up one day. I have a lot of GT-R notes. Lots of things people don't have on the interweb.
Old 20th August 2008, 05:08 AM   #9 (permalink)
but please answer me this, I CAN USED MY R33 GTR CAS ON R34 CAS, I JUST NEED TO RE WIRE THE PLUG??
THANKS I WILL WAITTING FOR YOUR ANSWER
JEFF
Old 20th August 2008, 07:28 AM   #10 (permalink)
Stachi's Avatar
You will have to use the R34 CAS with R34 Cams, because the drive is different. You will simply have to swap the pins on the plug.
I've never done it, but I don't think it's rocket science, looking at the wiring diagram and having repinned quite a number of things on cars.
But tyndago will confirm that, I think.
Marc
Old 20th August 2008, 07:31 AM   #11 (permalink)
Marc
so, i will need the r34 cas and re pin the plug and i am good to go?? my cas r33 will not work!! , ok
jeffrey
Old 20th August 2008, 07:35 AM   #12 (permalink)
Stachi's Avatar
Thats what I think. Maybe you can do a search on here? There are quite a few people on here that drive R34 Engines in R33 Chassis, maybe you could ask some of them. I think Moleman and Hodgie have R34 engines.. But I could be wrong.
Marc
Old 20th August 2008, 03:17 PM   #13 (permalink)
tyndago's Avatar
You can swap cams and cas. If you want you can put the R33 exhaust cam in and use the R33 CAS if you want in the R34 engine. Just need to check the valve clearance.
The plugs are the same, the wiring is different.
