#17 (permalink) |
actually us dealers are all saying from 100 to 200 launches.
some dealers are saying less than 100 to scare customers for the obvious reasons. they said that all the test cars were dying at 200 launches, and it was repeatable with all the test cars that the press got to test etc. so the us dealers have been saying 200 is the limit and try not to do that. this was from a nagtroc thread, i dont have th link |
#18 (permalink) | |
Lambo's wear out their clutches at a awful fast rate and that's without doing launch control starts!
Do it right or don't do it at all. "You're a pack of a**holes!" - Jim Richards 1992. スカイライン69 UK |
#20 (permalink) | ||
200 launches? If that really is correct, it's way stronger than most other production car clutches. For an AWD car straight from the factory to stick 200 launches is just amazing. I don't even think your average 2.0 litre, 2WD hire car would survive that. Quote:
Must be the clutches as they're an integral part of the DCT. It's pretty obvious that the clutches will go first. What designer in their right mind would produce a car with a clutch that's stronger than the rest of the gearbox? That's like fitting a 1000A fuse to a kettle. Last edited by R33_GTS-t; 24th August 2008 at 06:34 PM. |
#21 (permalink) | |
My GTR SUCKS..... air.... then big shiny turbos force it into the engine. |
#22 (permalink) |
The clutch isn't a warrantee item on any car in the UK as far as I know. Comes under the same classification as brake pads. They wear proportional to how they're used.
#23 (permalink) |
The clutch is indeed the fuse or if you drive an Evo more likely the Diff lol.
200 launches is quite amazing as I don't know of another performance car that could stick that number of launches without something cracking after a few dozen. No one is going to warranty a clutch - we can only dream lol.
#24 (permalink) | |
