Oil catch tank,standard engine. Worthwhile?
Rb26 standard except for induction kit,decat,exhaust and running .95 bar boost.
Obviously it's gonna stop hot, slightly oily air being drawn in, so I'm gonna get cooler, cleaner air for better combustion, and less of the oily residue inside, but is it significant enough to matter? I know a lot of guys running higher boost have them, but in all honesty, is it worth fitting a tank, or is it maybe some more blingy, silicony stuff for the engine bay? ![]() |
bit of both really...
im going to install one as i think it always helps.
STAGEA (BLACK) RB25 MANUAL CONVERSION + AERO KIT + MUCH MORE INC COILOVERS £6.2K VISIT OUR WEBSITES!!!!
www.neweraparts.com www.neweraimports.com www.neweramedia.com Japan Office Tel - Calls charged at UK National Rate): 0207-193-3979. Mobile ( Japan ): +81- (0) 90-4133-3825 Fax ( Japan ): +81-(0) 47-307-4678
i've got one for my 32gtr i keep getting it out of it's box to fit it ....but there is not many place to fit it so it keeps getting put back in it's box ....i was wondering also is it really worth the hassle i'm running 1.4 -1.6 bar boost so really if it helps to reduce knock i ought to install it anyone got any pictures of there installs on a 32 gtr ..
#6 (permalink) | |
can't really see from your picture as if not the oil vapour will still get into the induction mixture if you didn't thats probably why the idle is erattic the engine is pulling in air through the oil tank ...and the pipe going to the turbo is post the afm so the engine is taking more than the ecu thinks it is .. Last edited by miragev; 25th August 2008 at 08:46 AM. |
#8 (permalink) | |
![]() ![]() ![]() ![]() yeah, you got me there. I was that excited to get the tank in and plumbed up that I forgot to blank off the other sides. What a wally ![]() ![]() ![]() I feel suitably daft now ![]() TT |
#9 (permalink) | |
#10 (permalink) | |
![]() Cut them there pipes TT. ![]()
燃料バーナー
#13 (permalink) |
Could just go mines oil baffels and this will reduce the need and keep the oil where it needs to be .. just my 2p
To my understanding oil catch cans where designed to keep oil off the track when engines have expired ..not say they don't look nice. |
#15 (permalink) |
think i might alter the plumbing of mine a bit..as i have mine linked from the righthand breather to the tank and then back to the turbo.. i.e. as per factory standard but with the catch tank in line with the rear turbo breather.
I would guess at high boost oil vapour is going to be drawn through the catch tank and rear turbo back into the engine? Maybe I should vent it to atmosphere and put up with the smell? on a releated note,what does the PCV do (i guess its a pressure control valve) does it allow the crank case to breath.. if so why are people blocking it off? surely you want the blow by gasess to be drawn out of the engine (so as not to pollute the oil) and off to the catch tank or to atmosphere? |
