heard nothing but good things fabout the Ohlins on the track, but harsh ride on the streets and some need types to be removed from the car to adjust the springs. Can't comment on the hks ons though. Although in general the hks coilovers are also quite harsh on the road
Yeah Ive been told that the ohlins are harsh on the road but I don't drive the car very much and when I do its to the track and back. If there similar to the HKS with stiffness then thats what I'm looking for. My friend had an R32 gtr with the hyper max and I loved the way it felt.
I had HKS Hipermax on my car which were on when I got it - far too hard for me, and one of the rear shocker sprung a leak after less than 30k miles on the car. No-one in the UK seemed to be able to rebuild them at a worthwile price so they are garage ornaments now!
I've got Ohlins. No body roll at all. Beautiful handling, but they will jar the shit out of you on rough roads. Plus, you have to pull the coilover and disassemble it to make height adjustments, and you can only adjust height in set increments of about 1cm. The more expensive Ohlins have traditional screw-type infinite height adjustment, but they're way outta my price league, and the basic Ohlins are plenty good enough. Just a hard ride for the streets and a pain to adjust.
It depends on which Ohlins you get and the spring rates you option.
Japanese Ohlins are made my Yamaha...the question of rebuilding those in Australia has come up on SAU and so far no one has found a company to do it. Swedish Ohlins are still made there. These are the real deal, an excellent shock and can be rebuilt. Before you start ordering anything, make sure you research the spring rates. What you do with the car and the type of tyre your run, Semis-Vs-Street, will determine those. The idea of controlling body roll using high spring rates is a Japanese philosophy. Which is ok if you have super smooth roads/track and you don't ride the ripple strips. Best way to control roll is with a pair of ARB's. This way you have more latitude for tuning and you wont shake the fillings out of your head. |
#13 (permalink) |
You should probably be a little more specific because not only are the companies different, but they make different models as well.
For example the poster above said his HKS coilovers are very stiff, however my HKS Hypermax RS are fairly soft. They are a coilover made for the street. They ride amazing. So you have to be careful what you are comparing too and you need to know if you want to have a coilover for the street or a dedicated coilover for the track. |
#15 (permalink) |
![]() These are mine, very stiff! Thinking of changing the springs and getting some fat ARB's.
