intercooler paint
i am looking to paint /spray my fronjt intercooler with either nismo or something similar. does any one have any idea whats the best way of doing this and if anyone has any pics if they have done anything similar. i just want an idea what it would look like and dont wanna screw things up and have it looking shite.
cheers amar |
Black will actually radiate heat faster than any other colour BUT an IC works primarily by conducting the heat into the airsteam and not by radiating it so an additional coating just means that the heat has to work its way through another layer before coming into contact with air. The effect isnt all that great though as the paint layer is pretty thin.
Tbh id just use something like the "high temperature" manifold paint you can get in halfords etc. Its overkill for an intercooler but doesnt require a primer layer and goes on in nice thin coats with a satin black finish
Matt Skinner R32 GTS-4, R32 GT-R project |
correct me if i am wrong.
air impact of air on the ic will lower its temperature which in sequence will lower the temperature of the passing air inside the ic. black absorbs all of the light components while the white reflects them. so if the ic is painted black will tend to heat a bit more (much like white cars vs. black cars) what will cause the diminuishing of its cooling capabilities. but i could be wrong |
Have a read:
Black Body Radiation "In fact, we can be much more precise: a body emits radiation at a given temperature and frequency exactly as well as it absorbs the same radiation. This was proved by Kirchhoff: the essential point is that if we suppose a particular body can absorb better than it emits, then in a room full of objects all at the same temperature, it will absorb radiation from the other bodies better than it radiates energy back to them. This means it will get hotter, and the rest of the room will grow colder, contradicting the second law of thermodynamics. (We could use such a body to construct a heat engine extracting work as the room grows colder and colder!)" But radiation isnt really a major factor on an IC
#7 (permalink) | |
![]() seems to be doing alright for me ![]() it depends on how fast you are travelling, cold air flow over the intercooler fins. I used Hamerighte high heat paint Smokey
It's all about driving a race car on the street !!! 10.59@133 mph TOTB Handling 52.026 sec Snetterton Super Battle 2008 "No story sits by itself. Sometimes stories meet at corners and sometimes they cover one another completly, like stones beneath a river" |
m skinner, i have read that article before.
what i dont think i that it applies now. for that article to be applicable here, the inside of the ic should also be painted black so it would absorb heat from the air inside. as it does absorb heat from the radiation outside leaving the adjancent area colder (and not the interior area as it should). smokey, cant really see whats the point in posting a pic like that. we all know your car is great but wouldnt it be better with a thin layer of white/no colour? i actually tried that in my old evo. same turbo, same map, same boost, same ic, same road, same weather/air temp, same speed. in fact with a black ic i got an increase in intake air temp of 3º the same applies to intakes on jet engines on commercial aircraft (not the inner part, as it is all CF, but the outter part that is polished metal that helps to dissipate heat. as seen in CFM, RR, etc engines. |
M Skinner has said it a few times already - but radiation plays a negligible part in intercooler efficiency.
Intercoolers work by conducting the heat from the charge air into the metal, then into the air stream passing over the intercooler. Conduction through one body of any type is usually much better than between that body and the next (boundaries / film coefficients). Any new 'boundaries' will reduce the efficiency. In reality the coating on the standard I/C is so thin it will make very little difference, and the same goes for you painting a logo on it if you don't go daft. |
#10 (permalink) | |
If you currently have a silver IC that you want a black paint for then Frosts do a black paint specifically for radiator use : Radiator Paint on Frost Auto Restoration Techniques I've used it on radiators and heater matrix's and it seems ok.
Cheers Stu R32 GTR - Godzirra Twin turbo RB25'd 200SX RS13 - 405bhp and 348lbs ft on 15psi |
Lol, as long as you dont use Dulux max black gloss it'll be fine. A thin coat of any colour paint will make next to no difference to the efficiency of your IC. Esp if you are just going to dust a logo on through a mask.
#12 (permalink) |
This discussion is kind of pointless.. painting the IC black won't have a significant impact on the average intercooler temps compaed to if it is just plain. At least not to the point that you will be losing performance. Unless you have a full out race car and an extra 3bhp at max rpm is worth USD10,000 to you... or if you use a very heavy paint like "stagea" mentioned.
