vex
Cars owned: GT-R R35
World’s first Alcon R35 rotors
World’s first Alcon R35 rotors, installed…. or so says the local authorised distributor.
![]() Before rambling on, I state categorically that I am damn impressed with the stock brakes. They are very linear, powerful and fade resistant. This is not just my view but one shared by several highly competent drivers/friends. Incidentally, one of them did 2.28min flat at Sepang on stock brakes. But as we all know, drilled rotors aren’t well suited for track abuse i.e. standing on the brakes at above 240kmh, repeatedly. My stock ones cracked after 3 track days or slightly above 300 track km. Features of the Alcon rotors- alloy bell (saves weight) crescent grooves (provide more traction!) curved vanes i.e. the partitions between floating discs (aid cooling); stock ones are straight iron alloy disc (provides significantly higher durability and more weight saving). Saved 1 kg of unsprung weight per rotor (measured today). Sweet. First impressions- brake pressure required is as linear as stock wee bit of screech cos I have not bedded in yet remarkable brake torque- butt feel says at least 10% higher- prolly due to the crescent grooves. Will do 0-100-0 on driftbox when free. That’s all for now folks till I bring these babes to track ! As an end note, don’t bother to change rotors if you are mainly using your R35 for aggressive street driving; leave the brilliant stock brakes alone. -vex p.s. My other brake stuff- Seido-ya N1-500, 800 degC, about 60% left (using these because I cant afford the stock Brembo pads) Motul RBF 600 (my favourite brake fluid). ![]() ![]()
winsome
Cars owned: R35 GTR
hi vex
is the alcon rotor make specifically for R35 GTR? or you just located a similar size from their production? How much do they cost? Front and Rear Fitted? Thx Winsome
#3 (permalink) | |
vex
``We have already created replacement discs with increased heat capacity over the standard fitted, if this would be of interest to you in the short term.`` sgd2.8k for a pair or sgd5.6k for front and rear rotors. price is inclusive of freight via fedex. cheers
Marwan
Hi,
I recently purchased a GTR R35. As you are experts more than me, would you please tell me both front and rear rotors dimensions? I did some homework and I was able to get the front only as 380 x 34. Can anyone help me with the rears please? Maybe Brembo, Alcon or anyother manufacturers part numbers will help.
Marwan
Thanks Robbie for the quick response. I need to cross check with other manufacturers like DBA. I have no problem changing the hat once and keep changing the outer piece. This is why the dimensions are really important to me
Robbie J
is a new Dad
Moderator
Cars owned: GTR R35 and 350z (R33s Gone)
Untitled Document
don't have them listed AP Racing are around £300 each +VAT with todays exchange rate that should be good for you?
R35 arrived in June 08 |
#14 (permalink) | |
SKYLINE GT-R
is Feeling bad, my 4WD not working :(
Cars owned: 820 RWHP BNR32 @ 29PSI, 670RWHP BCNR33 @ 20PSI
check plz YouTube - MCPERFORMANCE's Channel good luck
#15 (permalink) | |
Marwan
