Old 30th August 2008, 07:17 PM   #1 (permalink)
Send a message via MSN to Jakobsen
Fuel tank level sensor - gauge
Hi...
Have been having problems whith my Fuel gauge, it dosent work )-: the problem startet after haveing build my R32 GTR to single turbo.. i took both the plugs off from the trunk to the tank but, it dosent work now when i plug both plugs in.. dont know what the problem could be ? Hope some off you have maby had the same problem's whith the gauge ??
Hope you understand the question. and sorry for my bad english
Jakobsen is offline   Reply With Quote
Old 30th August 2008, 08:13 PM   #2 (permalink)
Cid_Casterwick's Avatar
I'm having somewhat of a similar problem with my R32 as well. Ive got no fuel level reading but my light comes on when its low. I know that its getting voltage because if you take the cluster out the gauge goes to E (0%) and when its put back in and power is given to it it draws below E (like -10% lol) I have a feeling its missing a ground somewhere or the floater on the pump is hosed.
Cid_Casterwick is offline   Reply With Quote
Old 30th August 2008, 08:58 PM   #3 (permalink)
freakazoid3's Avatar
I had the same problem after the previous owner had the tank opened to empty it as he accidently filled her up with diesel
It was the floating part off the arm which has the potmeter on it that was bend a little. Might want to check the in-tank connections too
Old 31st August 2008, 07:15 AM   #4 (permalink)
Thanks... will check the intank parts. and maby trying go give the plug for the fuel gauge a ground connection maby that would make the gauge show some readings.. it's just weird that i now dosent work, havent done a think to the tank, had just had the car standing still in 3 mounths. and taken the plugs off ??
