Help needed please!
Right im not sure if im posting in the right area but here we go.
Right my R32 GTR starting misfiring at low revs but as soon as it gets over 4k it shoots off, since reading all the post on the forum thats causing the problem i tried most of them to cure the problem but no luck ![]() I first did was New set of NGK grade 7 Iridiums didnt work Took Air flow meters off n mate opened them up n solder them a bit didnt work. Took car into garage which had inner gaiter replace n a diagnostic check, it came up with Error code 21 - sumfink to do with ignition - Help on this one please Put new Splitfire coils in was working fine for a drive for bout 15mins then when i put my foot down a bit it started again. So im annoyed at the mo jus wana sort the prob out soon as. Please leave comments i get back here a bit later. |
im only down the road from you...if you need help
sounds like you need a new ignition amp
STAGEA (BLACK) RB25 MANUAL CONVERSION + AERO KIT + MUCH MORE INC COILOVERS £6.2K VISIT OUR WEBSITES!!!!
www.neweraparts.com www.neweraimports.com www.neweramedia.com Japan Office Tel - Calls charged at UK National Rate): 0207-193-3979. Mobile ( Japan ): +81- (0) 90-4133-3825 Fax ( Japan ): +81-(0) 47-307-4678
Hey guys! tried The Igniter amp werent that cause i borrowed one from Ron from RK.
Well i think its the wiring Loom itself now, as yesterday i spent hours on the car, Cover came off extand earth so it can clip on side. cleaned all earth sanding them etc to make sure it got good connection. Went for test run and it was spot on no problems driving hard and slow for an hour. Until later on the prob came bk wen i went out, stop on side of road and wiggled the connector and wire that goes to number 6 while engine was running then it was total fine! So gona get the loom from Ron tmoz as he got a new one which his not using. |
