Old 8th September 2008, 06:42 PM   #1 (permalink)
Darbo's Avatar
Hicas Removal and general can i also remove?
Im in the middle of removing the hicas on what will be my track/road gtr
ive removed the selenoid hicas thing from the o/s chassi leg
and ill be fitting a Greddy oilfilter/cooler relocation kit
where im putting the filter housing on the inner wing is close to the 2 port boost selanoid
? what is the ballast risistor type thing thats mounted under the boost selanoid do?
as im gonna have to move or remove it
also looking into the low pressure rack side im probley gonna relocate the std powersteering cooler into the N/S innerwing below the headlight
and remove the vanes on the redundant half of the p/s pump and blank the intake and outlet
then i can remove all needless pipeing
can anyone see any problems with that?
im leaving the hicas pipes underfloor as fuel lines as someone suggested on here incase i ever seek more power
im undecided what to do with the aircon as the car came with a near new aircom pump on it
but ill probley remove it
was gonna change the cambelt on it and have sofar snapped a britool and a mac crackbars trying to undo the crank nut
omg its tight
Darbo
Darbo is offline   Reply With Quote
Old 8th September 2008, 06:58 PM   #2 (permalink)
Yes it is bastard tight - I have a bent snap on breaker bar that would agree!
Old 8th September 2008, 09:40 PM   #3 (permalink)
Darbo's Avatar
I have done 2 other gtr timeing belts and they were just normal tight
this one is stupid tight
could do with a inch windy gun see if that shifts it
Old 8th September 2008, 11:34 PM   #4 (permalink)
pupsi's Avatar
Don't remove it, relocate it, the ballast resistor is for your injector's.
Old 9th September 2008, 12:29 AM   #5 (permalink)
Darbo's Avatar
thanks
thats what i needed to know
its abit of clutter really would be better up near the baulkhead maybe
Old 9th September 2008, 09:34 PM   #6 (permalink)
rb26dett crank bolt is 360lb/ft tight!!! get a huge bar!
RamRod is offline   Reply With Quote
