Benji Linney GTC
is stimulating the R35 tuning scene
AMUSE: Work of ART + Ecu
Hi guys,
We had a customer after an aftermarket exhaust as he felt the stock wasn't loud enough... No worries he came to the right place. He wanted the best money could buy, the best Japanese titanium ![]() ![]() ![]() This is what a GT-R's exhaust will look like after next to no time on UK roads. Just like the Intercoolers the exhaust was made to a budget. ![]() ![]() ![]() ![]() ![]() That's better ![]() ![]() ![]() ![]() ![]() No photo's will do the Amuse exhaust justice, the quality of material, workmanship, welds are stunning. The kit also comes complete with new Nissan OEM gaskets and brackets, which isn't the case with some other brands. The blue flame and gold rings maybe too extreme for some (like Nito) and there are variations available too. The only thing that i feel personaly lets the Amuse down is its not loud enough ! (sorry i'm a lover of monster RB rumble) Even with straight pipe. But the sound on down blip is sexual. Also decided to have a look at his ecu messages with the handy accessPORT ![]() ![]() ![]() AWD C1109 C1113 BCM U1000 B2014 B2553 B2562 B2601 B2604 B2607 B260 a B2612 B2617 MULTI AV U1000 CAN U1300 U1241 IPDM B2109 His battery got too low, most of the codes talk about a bad connector, or the battery voltage getting to low. Check engine light was not on, most these are all just historical codes that the different computer keep track of to help the dealership diagnose problems. AWD C1109 Battery Voltage Abnormal When the ABS actuator and electic unit (control unit) power supply voltage is lower then normal. possible cause: Harness or connector, ABS actuator and electric unit Battery might have gotten low when the car was flashed. C1113 G-SENSOR Decel malfunctioning. Possible cause: Harness or Connector ABS actuator and electric unit. yaw rate/side/decel G sensor BCM U1000 This is a CAN comms error B2014 CHAIN OF S/L-BCM Inactive communication between steering lock unit and BCM Possible cause Harness or connectors (Steering lock unit circuit is open or shorted) Steering lock unit BCM B2553 B2562 LOW VOLTAGE When the power supply voltage to BCM remains less than 8.8 V for 120 seconds or more Harness or connector (power supply circuit) B2562 B2553 IGNITION RELAY BCM detects a difference of signal for 2 seconds or more between the following information. Ignition relay (fuse block) ON/OFF operation Ignition relay (fuse block) feedback. Harness or connectors (ignition relay feedback circuit is open or short) Fuse Ignition relay IPDM E/R B2601 B2601 SHIFT POSITION BCM detects when a difference between the shift P input signal and the shift position signal received from IPDM E/R via CAN communication continues for 2 seconds or more Harness or connectors (Control device circuit is open or shorted) Control device (detention switch) B2604 B2604 PNP SW BCM detects the following status for 500 ms or more when the ignition switch is in the ON position. N position input signal exists. Shift position signal from TCM does not exist. N position input signal does not exist. Shift position signal from TCM exists. Harness or connectors [TCM circuit is open or shorted] TCM BCM B2607 B2607 S/L RELAY BCM detects that there is a difference between the following statuses. Steering lock unit ON signal transmitted by IPDM E/R The steering lock unit status feedback Harness or connectors (Steering lock unit power supply circuit is open or shorted) Steering lock relay (Built into IPDM E/R) B260 a B260A IGNITION RELAY BCM detects a difference of signal for 2 seconds or more between the following information. Ignition relay (IPDM E/R) operation request Ignition relay feedback from IPDM E/R (CAN). Harness or connectors (Ignition relay operation circuit is open or shorted.) IPDM E/R B2612 B2612 S/L STATUS BCM detects the difference between the following status for 1 second Steering lock or unlock Feedback of steering lock status from IPDM E/R (CAN) Harness or connectors [Steering lock unit circuit (BCM side) is open or shorted] Harness or connectors [Steering lock unit circuit (IPDM E/R side) is open or shorted] Steering lock unit IPDM E/R BCM B2617 B2617 STARTER RELAY CIRC An immediate operation of starter relay is requested by BCM, but there is no response for more than 1 second Harness or connectors (Starter relay circuit is open or shorted) IPDM E/R MULTI AV U1000 CAN CAN coms error. U1300 U1300 is indicated when malfunction occurs in communication signal of multi AV system. Indicated simultaneously, without fail, with the malfunction of control units connected to AV control unit with communication line. U1241 IPDM B2109 B2109 STRG LCK RELAY OFF IPDM E/R detects that the relay is stuck in the OFF position for about 1 second even if the IPDM E/R receives steering lock relay ON/OFF signal from BCM. Harness or connector (Power supply circuit) IPDM E/R Battery Errors now fixed
davew
is "Keeping the Legend alive"
Cars owned: R35,R34,R33,R32 and KGC10
now i would like to hear a sound clip of that exhaust Ben?
The GTR Shop - Skyline & GTR Supplier, Breakers and Parts supplier. Visit To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Check our Trade Forum for 100's of great value parts To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. or visit To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. For all your GTR needs. New and used. "mild to wild" GTR always in UK Stock, contact us for details Mobile +44 7731304953 Office +44 191 645 2585 Find us in facebook. Search - thegtrshop GTR店 We ship worldwide.
Alan
is HAS BEEN TO ABU DHABI F1 and F1 and F2 Powerboats
I agree, sound clips are required
----------------------------------------------------------- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. My bike,s got more BHP than most!!!! Don't make me get the bike out YOU WILL LOSE!!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Benji Linney GTC
aw a youtube sound clip just wouldn't do Amuse justice. I mean only one guy from Czech even noticed my car had a sunline on in the 5th Gear Clip !
I'll try my best to make sure this car comes to some GTROC meets like ACE etc..
Eric GTR
has no status.
a quality looking bit of exhaust work and good db's so shouldnt cause headaches on motorways
shame about the blued tips thou ..... can it be ordered without them?
#10 (permalink) | |
NITO
has no status.
Cars owned: V-Spec II Nόr
That answer your question ![]()
"She'll make .5 past lightspeed" |
Benji Linney GTC
***Update guys***,
we had this 35 back to us after almost 10 months we inspected the Amuse Titanium exhaust and quality is flawless... in fact gets better with ages and heat and don't forget how bad of a winter we had last year (no damage from salt on roads etc..)![]() ![]() ![]() watch out for my Titanium exhaust post coming up
