#32 (permalink) | |
#33 (permalink) | |
#34 (permalink) |
I'm sure Rob at RIPS posted about a belt drive pump he was working on which worked with the conventional sump, and you could keep a/c etc. Never saw much more on it or any prices but it sounded pretty interesting.
#36 (permalink) |
Not sure on either of those questions yet. It had perfectly fine oil pressure and then it started to knock, so I shut it down immediately and got it towed home. Cranked it over with the CAS unplugged and it had oil pressure but it was low, even for cranking. Drained the oil and checked the filter and there was copper and other metal shards in it. I changed the oil three times already since the motor was built (10 minutes of idle to seat the cams, changed oil, drove it home 50KM and changed the oil, and changed it again at 500 KM's) and there was never any metal in it before.
The wierd thing is I hadn't been beating on it. I had a high-RPM missfire from dead coils so I was pretty well only driving it off boost. The night it died I finally got my new coils in it and had gone WOT a few times, but only after it was warmed up. When it died I was giving it about 1/2 throttle, shifted from second into third at about 4000, let off the throttle and was cruising along at 3000 RPM's in third gear on flat straight ground and it started to knock. It died last Friday, but my Father had big surgery on Saturday morning, my girlfriend was in town, and it was thanksgiving so I didn't get a chance to pull the motor. I should have the motor out Friday night and get to check stuff out on Saturday though. |
#37 (permalink) |
So in the latest news, the #5 and #6 main bearings spun. Oil pump isn't broken, and the crank collar shows no signs of wear. Leads me to believe it wasn't assembled correctly :@
I'm thinking that over the winter I'll have everything torn down, checked for tolerances by a different shop and resassembled with all new bearings. With only 625 KM's I think I'll just leave the rings as they lay. See if I can't scrounge up some cash and put a tomei oil pump in it. Looking on the bright side, this gives me a chance to finally yank all the hicas lines out of there and cleanup/spotweld the engine bay. |
#39 (permalink) |
Chuck a bigger baffled sump in while the engine is out, Also a oil restrictor,and perhaps the oil return pipe mod at the back of the engine that seems to be the new talking point on here.
#40 (permalink) |
The rest of the motor all looked fine. No scarring on the cylinder walls, no signs of detonation on the plugs or the pistons, no carbon build up, etc.
I did a compression test the day before the bearing spun and it was 165 straight across the board, which seems right as I'm at 8.3:1 compression instead of factory 8.5:1 compression. Leakdown was under 3% on all cylinder. |
