Wiper Arms and Window Rubbers?
Good morning,
Does anyone know the best place to purchase wiper arms and window rubbers for the R32 GTR. The car is very mint but could do with a few new rubbers (maybe even a full set) and the wiper arm assemblies could also do with a refresh. Thanks Lee
Mint R32 is the way forward - now where has all my polish gone!!! |
seriousperformance.co.uk
Newera (Matty32 on here) or somewhere like RHD Japan I would think.
(OO\ WAX ME /OO) www.seriousperformance.co.uk The UK's No1 Car care and detailing supplier: Finish Kare FK1, Duragloss, Poorboy's World, Dodo Juice, Meguiars, Collinite, Aquatouch Microfibre, SP Products, Kestrel Polishers and many more! Large Range Of Detailing Kits Available Here!
As I have said befor there are alot of different rubbers to buy! The biggest problem is that they arent cheap!
From what I no you need to buy a complete set for front and rear and you have to take the windows out to be able to fit the new rubbers and plastic surrounds. Even then there are a couple of trim bits you dont get in the new set!!! I have tried to clean up my scuttle panel but theres a plastic/rubber piece attached which is knackered. I no the rubbers around the door shut top go (where the glass meets the b pilar), mine arent to bad. The rubber around the mirror bases split and that is a piece that goes around all the way around the door. Have you tried to clean up the plastic trim bits with T-cut and polish? Also try some rubber/vinyl restorer/cleaner on the rubbers. It can be hard work but the end result might show and you will save yourself a small fortune! OH, as for the wiper arms, take them off, rub down with 800, if you go to the metal use some etch priemer then spray with matt/satin black. A little tip for spraying them........get some wire and make a hook to hang them so you can easily spray the whole arm without having to touch it. Baz Last edited by P3RV3RT; 16th September 2008 at 02:09 PM. |
yer I was going to go down the spray route for the wiper arms was just being a bit lazy
![]() I had assumed that a rubber set would be on the high side but I am awaiting a call to get a price so I will see. There are a couple of rubbers that are grey now lol
Lee - Alex has some products that bring them up quite well (I hadn't done them for a little while).
If you put a couple of coats of his trim products on and keep them topped up, then they stay nice and black. As I say, I hadn't done them for a while as I was using the car so infrequently. I'm sure Abbey will come up trumps should you decide to change them though ![]() |
On finding out the costs I am going to refurb the wiper arms as I do work at an engineering company so I should really do them (was being a bit lazy
)Plus I did get some rubber stuff a few days ago so will give that a go. On another note I got loads of cleaning bits from alex and I am really impressed ![]() Lee
I have some very nice wiper arms front and rear
The GTR Shop - Skyline GTR Breaker and Parts supplier. We buy your crash damaged, broken or mot failed car for cash. call now. For all your GTR needs. From 1/2 clips to turbos, seats to shells , harness's to engines. call Mobile 07731304953 GTR店 We ship worldwide.
#10 (permalink) | |
Cheers Lloyd |
