Brake Master Cylinder Size
OK, I'm in Australia and I've come all the way over to your forum in the hope to gain some clarity on the size of a stock standard unmolested BMC on a 1990
R32 GTR. Choose from 15/16", 1", 17/16". Please only reply if you know 100% for sure. There is no size indicated on the casting. Thank you all. |
yours should be marked with one of the following BM
BM33 = 13/16 BM38 = 7/8 BM44 = 15/16 BM50 = 1" BM57 = 1 1/16 bm57 is the r32 brembo & r33 gtr one, should also be same for r34 gtr, think bm44 is the r32 gtr sumitomo one, will check later. hth Last edited by V1H; 18th September 2008 at 12:28 AM. |
Great. I'll assume you have an R32 GTR. Mine has no size indicated on the casting, does yours? Can I ask where you got the above info?
I've snooped areound a good Nissan dealer here and it seems the 1" is the std item, the 17/16" is for the GTR V-Spec R32s and R33s i.e. OEM Brembo equiped cars and the 15/16" is a 3 outlet unit for the N1 which did not have ABS (although I beleive it could be optioned). Seems strange that the N1 has a smaller BMC but perhaps that suits the non ABS set up better. Does this match up with what you know to be true? Cheers. |
S15 brakes
corresponds with other info on web, but then again they might have used the same source, however, think it is correct as some bmc are marked with both BM# and size. BM44 = 15/16 = 23.8 BM50 = 1" = 25.4 BM57 = 1 1/16 = 26.9 and from this: Brake Rotor / Caliper information -------------------------------------------------------------------------------- R32 GTST Master Cylinder diam (mm) - 25.4 area 506.71mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2 Front rotors (diam x thk) - 280×30 Rear Caliper Piston(diam x qty) - 38.18×2 = 2289.78mm^2 ratio FR = 2.239 Rear Rotors (diam x thk) - 297×18 total 7417.36 brake to master ratio 14.63 R33 GTST Master Cylinder diam (mm) - 23.8 444.88mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2 Front rotors (diam x thk) - 296×30 Rear Caliper Piston(diam x qty) - 38.18×2 = 2289.78mm^2 ratio FR = 2.239 Rear Rotors (diam x thk) - 297×18 Total area 7417.36mm^2 brake to master ratio 16.67 R32 GTR (Non V-Spec,) Master Cylinder diam (mm) - 25.4 Front Caliper Piston(diam x qty) - 40.4 ×4 Front rotors (diam x thk) - 296×32 Rear Caliper Piston(diam x qty) - 38.18×2 Rear Rotors (diam x thk) - 297×18 R32 GTR V-Spec / R33 / 34 GTR with Brembos Master Cylinder diam (mm) - 26.9 568.32mm^2Front Caliper Piston(diam x qty) - (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm^2 Front rotors (diam x thk) - 324×30 Rear Caliper Piston(diam x qty) - 40×2 2513.27mm^2 ratio FR = 2.1125 Rear Rotors (diam x thk) - 300×22 total 7822.56 brake to master ratio 13.76 This is the ratio of master piston movement to overall brake pad movement R32/GTR calliper ratio 15.43 R33/GTR calliper ratio 17.58 So there isn’t much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR callipers Oh...and an old favourite that seems to be a good practical test of what the theory suggests.... Car & Driver did a test a few years ago ...Test Car was a WRX (US Spec which only uses two piston sliding caliper, not as good as Nissan 4 spot or later Model WRX 4 pots) So tested kits were, std car, std car with upgraded pads and fluid, Brembo F50 Kit, Brembo Lotus Kit (Similar to as fitted to GTRs, 44/38mm pistons), Stoptech it and Prodrive Kit (Alcon) Stopping Distances 70mph - 0 , 3 Stop Brembo F50;_____________ 185 / 183 (Average / Best) Brembo Lotus; ______________ 200 / 196 Prodrive; __________________ 198 / 194 StopTech;__________________ 187 / 186 Stock; ____________________ 205 / 196 Stck with pads and fluid; ____187 / 184 The above figures are all in feet, one stop difference between pad and fluid upgrade to crappy sliding caliper brake setup and massive Brembos is 1 ft...lol 30cms And over 3 stops the average is 2 ft...lol 60cms So you can see the one stop max of the upgraded pads and fluid is damn good when you consider the $$$ to % difference. Stopping Distances 100mph - 0 , 25 Stop Brembo F50; _____________ 299 / 288 (Average / Best) Brembo Lotus; ______________305 / 294 Prodrive; __________________ 308 / 295 StopTech;__________________ 297 / 290 Stock;_____________________ 340/317 Stck with pads and fluid;_____316/299 Not the world of difference you would be led to believe by the "you need 6pot caliper 343mm rotor crowd." Specs of the kits: Rotor Weight (pounds) Size in inches (diam / thk) Brembo F50;.................15.8......................... .13.1 / 1.3 Brembo Lotus;..............12.9.......................... 12.9 / 1.1 Prodrive;......................16.5............... ............13.0 / 1.1 StopTech;...................13.9.................. ........12.9 / 1.1 Stock;.................. ......14.2..........................11.6 / 0.9 Caliper Weight , Piston Size, (mm) Brembo F50;..........8.6 pounds...........40 / 44, Leading / Trailing Brembo Lotus;.......6.8.......................36 / 40 Prodrive;...............9.1..................... 34.9 / 41.3 StopTech;.............9.3.....................36 / 40 Stock;.................10.8.................. .43 / 43 ...and COST!!! Brembo F50;.......................US$2,995 Brembo Lotus;.....................US$2,595 Prodrive;.............................US$1,999 StopTech;...........................US$1,695 Stock with pads & fluid;....... US$130 R32 GTST Front rotors (diam x thk) - 280×30 R32 GTR (Non V-Spec,) Front rotors (diam x thk) - 296×32 R33 GTST Front rotors (diam x thk) - 296×30 Different caliper to R32 GTR but same disc diameter. R32 GTR V-Spec / R33 / 34 GTR with Brembos Front rotors (diam x thk) - 324×30 R34 GTT Front rotors (diam x thk) - 310x30 The calipers that suit larger diameter discs have longer mounting legs to space the caliper out further. quote from: Brake Rotor / Caliper information - GTRCanada - Canada's premier skyline enthusiasts club |
#9 (permalink) | |
Where are you getting your info from? |
#10 (permalink) | |
Thanks for all the info. So has anyone seen a BM50 with 1" in the casting? Or has anyone got a way of 1000% validating this? Tis confusing.
#12 (permalink) |
you're thinking too much
, i've got a 32gtr with bm50, and even with stainless lines, brake stopper and uprated pads, the pedal had a long travel with not much bite, now uprated to bm57 from an r33gtr and the pedal travel is less with more feel and easier to modulate. This was with a bbk and the bm57 was needed(will work without but much better with) to fill up the extra capacity of the bbk.re: the bm50 rating, can't 1000% validate that but can validate a bm57 marked with 1 1/16. |
#13 (permalink) | |
#15 (permalink) |
Hi everybody, I'm from Russia
I need your help. Does enybody know an original part number of Master Brake Cylinder Tokico BM57. This is original cylinder for R32 GT-R V-Spec, R33/34 GT-R with Brembo brakes. If there are different brake cylinders on these cars, tell me please all part numbers. I need this for my Nissan 180SX. Sorry for my English. |
