Old 18th September 2008, 03:51 PM   #1 (permalink)
how to test cam angle sensor?
my r34 won't start. the car previously had a r33 cam angle sensor in it, and i wanted to put it back to original so we put a BNIB (brand new in box) r34 cam angle sensor in it, and re-pinned the connector appropriately.
josh with RB who came out to put my motor in, said he believed the injectors weren't firing. we re-pinned the connector back to r33 and plugged in my friend's r33 sensor (modified wheel to run an AEM EMS) and even though it won't bolt up to my r34 tomei cam, he spun the sensor by hand while someone was cranking the motor and we could get the motor to at least backfire slightly.
this leads him to believe that my new r34 sensor is defective.
is there a way to test this?
1990 Grey R32 GT-R - Sold!
1997 White R33 GT-R Vspec - Sold!
2000 Black R34 GT-R Vspec
1990BNR32 is offline   Reply With Quote
Old 18th September 2008, 08:07 PM   #2 (permalink)
R32 Combat's Avatar
On the AEM, log the CAS output voltage. It should go 0-5v in a square wave.
Old 18th September 2008, 08:15 PM   #3 (permalink)
kismetcapitan's Avatar
would a poor man's solution be to use a multimeter and turn the CAS by hand? I am assuming that the sensor is either on or off based on position, one could turn it and see it read 0v and then 5v at the correct points?
Old 18th September 2008, 08:51 PM   #4 (permalink)
i should have been more clear, the r33 cas was from my friend's r33, his car is the one with the AEM EMS. I have a stock ecu and a hks fcon vpro.
Old 18th September 2008, 08:54 PM   #5 (permalink)
i am handy with a multimeter, just need to know what to measure and what to look for?
Old 18th September 2008, 08:56 PM   #6 (permalink)
hyrev's Avatar
The 33 and 34 CAS are different but you can use them interchangably, IIRC. In order to do that, you have to switch 2 wires around, which ones I do not know. Search on here to see which ones need to be switched back.
hyrev is offline   Reply With Quote
Old 18th September 2008, 08:59 PM   #7 (permalink)
hyrev's Avatar
Ok, this should be the solution you are looking for
tah-dah
Old 19th September 2008, 01:37 AM   #8 (permalink)
yes, thank you, i have spoken with sean and i am aware of how to re-pin the wiring plug to interchange the R33 and R34 sensors. I am not interested in running an R33 sensor since it will not bolt up to my Tomei R34 cams.
i was inquiring about whether there was a way to use a multimeter to test my r34 sensor.
Old 19th September 2008, 09:53 PM   #9 (permalink)
there is , i just did this 2 days ago
its in the r32 gtr manual, i have on cd, i supose you can get a pdf somwhere on the net.
cant remmeber the page,
if you can wait till tomroow, i will tell you the page.
you have to read the voltage coming out of the 1 o 120 degree pin , wich is pin 1 and 2 looking at the conector off the cas, its the 1rts and second from the left.
hpt_simon is offline   Reply With Quote
Old 20th September 2008, 10:08 AM   #10 (permalink)
hi,
back in ofice now
well its page en-206 on the r32gtr manual, i suppose its the same as the r34 except for the dirferent pin order.
the way to test:
with ignition switch on:
0V or aprox. 5V between terminal (2) and ground (1º signal)
0V or aprox. 5V between terminal (1) and ground (120º signal)
battery voltage (12...) between terminal (3) and ground (power)
when cranking engine:
2-3v between terminal (2) and ground (1º signal)
aprox. 0.5V between terminal (1) and ground (120º signal)
and no need for test with idle , as it doesnt work right now :P
i just copy pasted this, so its same in the manual
hope this helps
simon
Old 21st September 2008, 07:18 AM   #11 (permalink)
you sir are the man.
Old 9th October 2008, 11:49 AM   #12 (permalink)
zbloke's Avatar
R33 GTR CAS Voltage
Just wondered if anyone knew if the R33 CAS voltages are the same as the R32?, reason I ask is;
On terminals 41 + 51, the 120º signal, I have a voltage fluctuating between 1.2v and 1.6v on idle and on page EN328 of the R33 Engine Manual it gives a figure of 1.3v for the same terminals on idle, however in the pin out section of the same manual, page EN433, it gives the expected voltage at the same terminals to be 0.3v >> 0.7v, same as the R32...........misprint on page EN328 in the R33 manual?
The other CAS signal on terminals 42 + 52, the 1º signal, is steady as a rock at 2.6v, the figure given on page EN328 of the R33 Engine Manual, (even though they have got the pin numbers wrong for this reading ) and this ties in with the information on page EN433, of 2v >> 3v on idle and the same info in the R32 manual.
Just want to be sure before I spend the best part of £300 on a new CAS
Tim
zbloke is offline   Reply With Quote
