Old 21st September 2008, 10:38 AM   #1 (permalink)
Front outer Upper bush
My front top outer bushes have shed loads of play in them shown in the FAST image, i take it that these are the camber bushes that 'WhiteLine' supply etc to alter the camber! but I've got adjustable top arms so just want some non adjustable replacements, on FAST and it only lists the complete arm (at a guess v expensive)
If replaced with camber bushes do the old ones need pressing out??
Any help or pointing me in the right direction would be a great help, yes i did use the search thingy I always do.
Many thanks
gavoh is offline   Reply With Quote
Old 21st September 2008, 09:18 PM   #2 (permalink)
StretchGSK's Avatar
I spent a bit of time looking up info on this as that exact bush on my R34 is making a horrible creaking noise and apparently the labour to replace the bushes alone is $$$
There was a suggestion to buy the complete Nismo link & bush kit.
I am not sure exactlly how many parts are needed but they are not as expensive as I feared considering you are getting uprated Nismo parts
Check out:
NISMO | NISMO Suspension Link & Bush Series
Be good to get some feedback from people that have installed these
StretchGSK is offline   Reply With Quote
Old 21st September 2008, 09:29 PM   #3 (permalink)
Check out:
That is just the web page i've been looking for Just had a look at the bush i need part no 54545-rs590 'front third link bush' and it says for all 4 3150 yen which is about £17 that's really good value.
Old 22nd September 2008, 10:01 AM   #4 (permalink)
Sub Boy's Avatar
I've fitted the Whiteline bushes all round on the GTR.
The factory ones are a little messy to get out.
I got the rubber bushes burnt out with a blow torch, and then ground down the last part untill I could pry the rest out.
Old 22nd September 2008, 01:41 PM   #5 (permalink)
R33 STIG's Avatar
Erm, I think you're mistaken mate... That's each - before you factor international bank transfer costs, carriage, etc. You also require a press & special inserts to remove & fit the new ones. May be better off buying new complete Nismo parts, unless you wanna do as Sub Boy above suggests. Be careful not to damage the original part or the new bushes when fitting...
R33 STIG is offline   Reply With Quote
Old 22nd September 2008, 07:14 PM   #6 (permalink)
Yep, i realised that was 'each' earlier today, read the Nismo page wrong (thought it meant 4 per pack!!!). Abbey have some in at £20 each + VAT so will probably get them, we got a press and ways to get old ones out so that ain't bothering me too much.
Old 22nd September 2008, 08:14 PM   #7 (permalink)
Sub Boy's Avatar
Yes you do have to be very carefull if grinding the last part of the bush out. I used a Powerfile, but you could use a dremel or a die grinder.
I tried to get them pushed out in a press....But they wouldn't move!
