Old 21st September 2008, 04:53 PM   #1 (permalink)
Camber
Hi guys, can the camber on the rear of a R33 GTR be adjusted if so can anybody put a picture up of what the camber arm looks like and how it can be adjusted. Thanks
richardr33 is offline   Reply With Quote
Old 21st September 2008, 09:58 PM   #2 (permalink)
reefyman's Avatar
no not as standard,i had too buy adjustable upper rear arms then you have plenty of adjustment(cusco) from rhd if memory serves me right.
reefyman is offline   Reply With Quote
Old 26th September 2008, 02:33 PM   #3 (permalink)
Spoke to RB today and they said you can adjust the rear camber, so if anybody knows how to or they can steer me in the right direction.
Old 26th September 2008, 08:25 PM   #4 (permalink)
FUDR33GTR's Avatar
Mate where are you based??
FUDR33GTR is offline   Reply With Quote
Old 26th September 2008, 10:32 PM   #5 (permalink)
iceager's Avatar
Send a message via MSN to iceager
Im sorry you are VERY wrong here my friend....
The Rears can be adjusted as the bolt has a welded ofset spacer on it ( the hole is not in the middle )
The head of the bolt/welded spacer have adjustment marks on it, so you will know what bolt it is. it can adjust +- 5mm i think.
This is the bolt you need to locate:
I knew i should have taken pictures of it, well i have to do that on monday when i get on the lift again.
iceager is offline   Reply With Quote
Old 27th September 2008, 10:06 AM   #6 (permalink)
I live in Preston, RB motorsport told me that you can adjust the rear camber, so if you cant they are the ones that are wrong, are you saying you can adjust it 5mm? any more than that then you need adjustable arms.
Old 27th September 2008, 12:37 PM   #7 (permalink)
iceager's Avatar
Yes more than that and you need to replace them with adjustable arms. But you will be fine for stock if you dont have lowered your car more than 40mm give or take a few.
Old 27th September 2008, 04:31 PM   #8 (permalink)
Thanks for the diagram mate I adjusted it and its fine. Thanks
