Aluminum Drive / Prop Shaft
Would like to know more about Aluminum Drive/Prop Shaft.
How are these compared to the Carbon ones? Anyone with any experiences? I came across The Driveshaft Shop and they have aluminum ones for sale and I think they are a fraction of the price of a Carbon one. Correct me if I'm wrong. Since we are on the topic of prop shafts, those who have Carbon Prop shafts, are they noisy? Would love to hear from those who are running them on the street with 500+whp and listen to experiences. |
I know a friend of mine bought an alli prop and needed to get it balanced although it was supposed to have been from the factory. I thinks its that they are only run up to 60mph at the factory and at that speed was prob okay.
Would be interesting to me how the ends are fixed on the Ali Propshaft. I think welded and maybe threaded..
I've once seen a carbon fibre propshaft and it had GKN cardan joints from Germany.. which kinda impressed me. Marc
sloathy,
Which company was this aluminum prop shaft purchased from? Stachi, No idea. Would really like to know too. Anyone with any experiences at all? What about experiences with a carbon prop shaft on a street car? |
A lot of alloy and carbon props have the end forgings glued in. Some racing bodies insist on mechanical retention, so they add 3 or 4 pop rivets to meet the letter, if not the spirit of the regulations
Glueing, done correctly, is fine, there being some brilliant adhesives available these days. A lot of commonly fitted two piece aftermarket wheel rims are glued together... |
Aluminium driveshaft
This is standing under the aluminium driveshaft product on Driveshaft shops website:
"The aluminum shaft has many advantages over the carbon steel shafts that most people are not aware of. The most obvious being the fact that it is 1/3 less weight, but the other thing that makes it attractive is that its resonant frequency properties are much higher. What this means to you is that a steel shaft may amplify a vibration where an aluminum one will dampen a vibration. The other thing is that an aluminum shaft torsionaly twists 19 degrees and a steel shaft only twist 5 degrees. What this means to a hot rod is the shaft will have a more dampened effect taking the shock load out of the drivetrain, making it more fluid feeling. Shafts can be made to handle power from mild to wild." |
#12 (permalink) |
Duh, I don't know why it didn't occur to me to read what they had on their website. How silly of me. (in a sarcastic tone)
![]() On a more serious note, I've already bitten the bullet and ordered an ACPT CF Prop shaft. Just awaiting delivery. ![]() |
