Old 24th September 2008, 07:09 PM   #1 (permalink)
T.F.S.'s Avatar
Thumbs down 0 compression
hi
had an issue with the skyline last night...was on the motorway at about 70mph in 4th when i gave it a bit of gas, i saw max boost and then the knocklink lit up, i came off the throttle straight away
no noises from the engine, no smoke, no nothing but no power under throttle and no restart....will not fire
as far as i was concerned this was most likely an electrical issue not an engine issue but today i pulled the sparkplugs and comp tested (with a new untested compression tester) just incase
0 compression....i tested 4 cylinders and didnt bother with the other 2, i think there was 25psi on piston 3
the engine was a home build and had done about 15-20 thousand miles since i rebuilt about 2 years ago, doing it again is no big deal i guess
i find 0 compression on all cylinders odd TBH, what do you think?
T.F.S. is offline   Reply With Quote
Old 24th September 2008, 07:17 PM   #2 (permalink)
360/PS3: TrevSkyline
Trev's Avatar
Bugger!
I know what your feeling - that said, I'm sure your rebuild it bigger and better.
12.7 @ 116 mph, Santa Pod May 2005
Old 24th September 2008, 07:19 PM   #3 (permalink)
T.F.S.'s Avatar
kind words trev
Old 24th September 2008, 07:40 PM   #4 (permalink)
HardcoRe GTROC Member
SmigzyGTR's Avatar
Ah sh1t, hope you get it sorted bud, i've never heard of the compression on all cylinders going though?
Ben
スミグズ
My GTR Development Thread - Team QM1
GTROC North West Regional Rep
Life is not a journey to the grave with the goal of arriving safely in a prettily preserved body, but rather to skid in sideways in a shower of gravel and party shards - thoroughly used, utterly exhausted and loudly proclaiming "f**k me, that was brilliant!!"
SmigzyGTR is online now   Reply With Quote
Old 24th September 2008, 08:10 PM   #5 (permalink)
T.F.S.'s Avatar
yes, my thoughts too
i had to put something down the hole to see if the pistons were still there lol
dodgy compression tester maybe, might swap it over with another tomorrow and retest.....maybe thats grabbing at straws lol
Old 24th September 2008, 08:58 PM   #6 (permalink)
Abbey M/S's Avatar
sounds to me it may have broken a cam belt bent all 24 valves.....
Old 24th September 2008, 09:20 PM   #7 (permalink)
driftboy's Avatar
Dito above, def sound like a bent valve issue... you got in there before me mark...lol
sorry to hear about this mate, never a nice feeling...
driftboy is online now   Reply With Quote
Old 24th September 2008, 09:24 PM   #8 (permalink)
T.F.S.'s Avatar
penny just dropped thanks
Old 24th September 2008, 09:30 PM   #9 (permalink)
T.F.S.'s Avatar
i just checked it and the cams still rotate during cranking
Old 24th September 2008, 09:35 PM   #10 (permalink)
Abbey M/S's Avatar
better have a look a the cam timing and valve clearances I think.
Have you got a cylinder leakage tester or if not cobble something up to allow you to pressurise the cylinders , you can then tell where the compression is escaping to
Old 24th September 2008, 09:41 PM   #11 (permalink)
G40tee's Avatar
do you have adjustable pulleys?
could one of them have slipped and put the valves out?
cant be cambelt as engine wouldnt do anything obviously.
i think its going to be head off time!
Back to the good old days! :-p
Christmas present for me maybe??
G40tee is offline   Reply With Quote
Old 24th September 2008, 09:56 PM   #12 (permalink)
Darbo's Avatar
i thought skipped teeth on cambelt
bummer though
least its not to bad to fix
had one last week
the fanbelt tensioner had gone and as the fanbelt snagged for a second it jumped one tooth on cambelt clockwise and one on the diesel pump anticlockwise (pug diesel)
no damage done new belt fixed it
Darbo is offline   Reply With Quote
Old 24th September 2008, 10:00 PM   #13 (permalink)
G40tee's Avatar
well you dont know the damage yet!
not hard to fix but could be costly!
Old 24th September 2008, 10:01 PM   #14 (permalink)
T.F.S.'s Avatar
no compressor for a leakdown tester im afraid
pulleys are std too, maybe it skipped a tooth or two but would it bend all valves in that case?
Old 24th September 2008, 10:15 PM   #15 (permalink)
G40tee's Avatar
you wouldnt have thought so. epec not for a couple of teeth. it couldnt have jumped that far.
would love to know what happened! as you probably do i imagine! haha
