Old 28th September 2008, 04:00 PM   #1 (permalink)
Dying R33 GTR rear turbo?
Hi i'm new to my R33 GTR, but been doing GTi-R's mine and other for years. Bought my R33 GT-R a month or so dead and off the road, cracked head already off and a bucket of rusty bolts, Took the lump out complete and fitted a complete low mileage engine (turbos inc the lot) (with restrictor missing from turbo solenoid as it was when i bought the engine so obviously been pushing more than bog stock) all good, been spanking it (stock gtr with exhaust/filters/hard pipes/apexi cooler and a bar) around sideways and like love it 500 miles of fun, firstly noticed leaness on my wideband, so clean both mafs wich were dirty cleaned and all good 11.8 afr @ wot. But intermittanly when downchanging and boost hard can hear like a tinging noise/pinking hmmm? and now sounds like the rear turbo is blowing very slightly and rattling on rev up from idle, i read on here the rear goes first could this be the start, i have some spare turbos so thinking will fit the front one to the back and go from there? what ya reckon chaps?
Olly-R is offline   Reply With Quote
Old 28th September 2008, 04:53 PM   #2 (permalink)
n boost's Avatar
Check your exhaust and manifold gaskets and also the nots/bolts to make sure nothing has worked loose.
If u are getting a pinging noise i would check it before booting. What fuel are u using and does it have a stock ecu or aftermarket?
n boost is online now   Reply With Quote
Old 28th September 2008, 06:50 PM   #3 (permalink)
Will do fella tomo, but i always aim for the worst case, but hopefully the turbo just worked loose on the manifold, and the rattle isn't pinking and just the turbo being loose or what evers left of the gasket ;-)
Old 28th September 2008, 08:15 PM   #4 (permalink)
ru'
ru''s Avatar
Could be just the turbo heatshield (assuming it hasn't been ditched)?
Old 1st October 2008, 02:25 PM   #5 (permalink)
rear turbo gasket to manifold blown apart, will screw back together tonight
Old 1st October 2008, 05:08 PM   #6 (permalink)
ru'
ru''s Avatar
Phew! Cheap fix.
Old 2nd October 2008, 02:14 PM   #7 (permalink)
tarmac terror's Avatar
How much did you pay for turbo gaskets??
I'm going to be changing my turbos pretty soon but was quoted some crazy numbers for gaskets..
TT
Old 2nd October 2008, 02:20 PM   #8 (permalink)
Listerofsmeg's Avatar
Send a message via AIM to Listerofsmeg Send a message via MSN to Listerofsmeg
manifold to head gaskets are the worst, but manifold->turbo are normally about a fiver a pop same as turbo to elbow.
The small paper gaskets you can normally get a full set in a box for ~40 maybe? that will come with fresh copper washers for everything too.
White R33 GTR
Its working!!
10.908 @ 128mph on pump fuel and full trim!
