Rear Wheel Bearings R32GTR
Hi guys,
since having my car for 6 weeks the wheel bearings have been shot on the rear, now i have been putting it off for weeks but the time has come, anyway i have been told that i cannot just buy a bearing but that i need a complete hub??? if anyone could recommend a place to source the parts i need to change the bearings i would really appreciate it , Thanks Jim |
or i can supply you with a complete hub
The GTR Shop - Skyline GTR Breaker and Parts supplier. For all your GTR needs. From 1/2 clips to turbos, seats to shells , harness's to engines. call Mobile 07731304953 GTR店 We ship worldwide.
which side hub?
this part?
i would have thought that the bearings just press out of the hub?? had mine apart ages ago but couldn't tell as the axles rust in the bearings so they have to be pressed out as well - normally a tap with a mallet will remove them.
you are after the "flange wheel bearing" which bolts to the hub itself. If my copy of FAST was working, I'd get you the part # too - but your Nissan dealer should be able to source a pair easily - or see Matty @ Newera!! (I should get commission for these referrals!!) |
