R33 GTS and GTS-t body shells, are they the same??
Looking to buy a 2 door R33GTS-t as a base unit for race use, shell will be stripped bare and sent for a weld in cage fitment, carbon doors and lexan glass. I am now wondering if I could buy a none turbo GTS 2 door and use the shell from that? Is the shell exactly the same? I have a GTS-t with an RB26 engine, with race running gear, so issues like diff, suspension and hubs won't matter. It's just the basic body shell I am after. GTS ones are cheaper and less likely to have been "abused" especially in automatic format.
Thanks. |
The GTR and GTS-T shells are so similar (engine bay, gearbox mount are different) I would be very surprise if it was not the case with the GTS.
Simon
Composite Design Studio webpage Doing it is not enough - it has to be done right. My Auto Journal |
more or less, some body bits are not stamped out (like hole for intercooler pipework) but other than that everything else is sweet like subframe mounting points, gearbox mounting points etc.
(im going off a non turbo 2.5 gts though, not certain about 2.0 but dont see why it should be different) |
GTS, GTST Shell
The GTST and GTS shells are basically the same, only real major difference is the engine and supporting components i.e. Differential, sway bars, brakes, GTS metal not stamped out for intercooler and most came as automatics, and they all had RB20E for powerplants, also hubs are 4 lug not 5. An RB26 and supporting components will drop in with no major obstacles involved.
